Wing to bulkhead bolts - Defender Source
Old March 1st, 2015, 01:53 PM
RockShow's Avatar
RockShow
Ben Goodwin
1996 D1
Are the wide thread bolts that fix the wing to the bulkhead longer on a NAS truck with the A-pillar hoop brackets? Or do you have to switch out the captive nut inserts for a regular thread count and use a longer regular bolt?
I am putting a hoop on my ROW 90 and the bolts only tighten down one turn or so because of the added thickness of the under the wing bracket.
Old March 1st, 2015, 02:32 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
I switched out the captive nuts on the bulkhead to a SAE thread so that I could use regular bolts. Lowes seems to have a good supply of those. You can also find some stainless at marine stores or a good Ace Hardware.
Old March 1st, 2015, 02:51 PM
Baldewin's Avatar
Baldewin
Chris Baldewin
Bastard 90
Yes they are.
bulkhead mounting bolts? boswalt Defender Technical Discussions 0 April 4th, 2013 06:23 PM
Check your chassis/bulkhead bolts! chris snell Defender Technical Discussions 7 July 13th, 2012 08:57 AM
two bulkhead bolts...removal question Gkase Defender Technical Discussions 7 November 3rd, 2010 05:33 PM
Frozen bulkhead bolts removal suggestions? Tyler Wirken Defender Technical Discussions 12 July 23rd, 2008 04:29 PM
stainless wing bolts rgrrvr Defender Technical Discussions 1 June 28th, 2007 07:15 PM
