Wing Protector Installation - Defender Source
Old July 21st, 2006, 03:54 PM
outfield
Steve
1995 D-90 SW #351
When installing the wing protectors, is any type of insulation used between it and the body? Any install tips would be great.
thanks
Steve
Old July 21st, 2006, 03:57 PM
fleabus's Avatar
fleabus
Dan
None :(
I used pond liner (from Home Depot) and used 3M spray ahdesive to attach the liner to the wing protector.
Old July 21st, 2006, 04:40 PM
Pond liner works great, OEM Rover stuff comes with a die-cut pad.
Old July 21st, 2006, 07:59 PM
sheki's Avatar
sheki
David Shechter
97' D90 SW 2.8L diesel
1/16" rubber, use the wing protector as a template then spray 3m adhesive on all surfaces.
this will prevent the wing protector from vibrating and driving you insane.
Originally Posted by MuddyOval
Sheki, you are a wang too.
A wang is another word for, you guessed it, A DICK!
Nothing racist, just pure DICK!
Old July 21st, 2006, 11:46 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
I just waxed well both wings and wings protectors.
If you put some insulation stuff, it will keep water
out, BUT if water goes in beetween (and it will...),
then how it will come out...
I used 3/16-32 x 3/4 button head socket s/s screws
with nylon and metal washers under and nylock nuts.
Remenber to paint the holes.
- Charles Eames
Old July 22nd, 2006, 08:40 AM
ronward's Avatar
ronward
Redsrover
None - sadly
Pond liner worked great for mine, pop rivet in place.
Anything is possible, with the right tools...
Old July 23rd, 2006, 11:03 AM
outfield
Steve
1995 D-90 SW #351
Pond liner ? looks like i need to do some shopping at a pet store.
thanks for all your input...
Old July 23rd, 2006, 11:40 AM
Pond Liner from Home Depot
Old July 23rd, 2006, 01:33 PM
outfield
Steve
1995 D-90 SW #351
Thanks, the wife just told me to check Home Depot too
installation, protector, wing
Wing Vents mlw911 Defender Technical Discussions 17 June 28th, 2004 11:26 AM
Need Left Wing outer shell vnrover Wanted 8 April 8th, 2004 12:56 PM
wing protectors Campbell Wanted 7 March 25th, 2004 05:21 PM
Mounting wing top protectors Chaucer Misc. Chit-Chat 5 March 10th, 2004 07:34 AM
For sale: Daimond Plate Half Wing Protectors Burke For Sale - Parts 0 January 25th, 2004 11:20 AM
