Wing part identification - Defender Source
Old May 25th, 2013, 01:40 PM
myoverlandrover's Avatar
myoverlandrover
josh
109
I'm looking for the "official" name of the aluminum headlight panel on the front of the wing? Mine is bent to heck and ideally needs replacing as the plastic cover and headlight assemble are all fitting funky. Any direction on where to buy would be awesome
borrowed this image from another post but mine is a newer defender so similar
Defender 110
Old May 25th, 2013, 04:23 PM
jafir's Avatar
jafir
Jafir Elkurd
I think most parts places have them:
http://www.roverparts.com/Parts/RTC6353.cfm
They vary a little with how the turn signals and side light mount, I guess.
Old May 25th, 2013, 05:39 PM
defeyago's Avatar
defeyago
Santiago
96 Defender 110 VGTdi SW County
This is your right part.
http://www.roverparts.com/Parts/ALR7972G.cfm
Cheers,
SANTIAGO
97 Defender 110 Tdi SW
04 Freelander Td4 5 dr.
97 Alfa Romeo 146 TD (Sold)
95 Volvo 850 GLT Estate
94 Discovery Tdi (Webasto equipped)
Old May 25th, 2013, 06:17 PM
myoverlandrover
josh
109
Thank you both! Actually looking for early td5 110 panel in black if painted is an option.
Defender 110
Old May 25th, 2013, 06:42 PM
defeyago's Avatar
defeyago
Santiago
It would be ASW710140 and ASW710150 then...
Cheers,
SANTIAGO
Old May 25th, 2013, 06:44 PM
I'm not seeing the problem in the picture. You should be ale to hammer out anything that is covered by the plastic piece and never see it.
Originally Posted by pendy
I'm here for the D's
Old May 25th, 2013, 08:58 PM
myoverlandrover
josh
109
as noted pic is not my truck just a reference for the part i need. I know I can live with what I got but just trying to figure out what it would cost if I want to rebuild it. I do need the headlamp leveling bowl as mine is cracked in half practically. It looks like someone was in an accident or hit a tree and finagled it together.
Thanks for the numbers defeyago, i emailed craddocks for quotes
Defender 110
Old May 26th, 2013, 10:18 AM
My bad, missed that when reading your post.
Old May 26th, 2013, 03:09 PM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
Pic is of my truck...
part, wing
Part Identification. ajh Defender Technical Discussions 2 February 23rd, 2010 10:30 PM
Part Identification TDI Guy Defender Technical Discussions 3 January 23rd, 2009 07:38 PM
Part Identification grinch79 Misc. Chit-Chat 1 November 25th, 2008 01:51 PM
need a part # or info on where to buy part yellowrover Defender Technical Discussions 4 August 3rd, 2004 09:55 PM
Lucas problem; need part number sherpamike Defender Technical Discussions 4 May 26th, 2004 10:27 PM
