Windshield Wipers - Defender Source
Old January 5th, 2008, 09:12 PM
kennybahr's Avatar
kennybahr
Kenny Bahr
94 D90 Alpine White #1245
Windshield Wipers
Ok, I got my d90 about 3 hrs ago, I'm very excited, however, the fuse to the windshield wipers was blown upon delivery. I changed the fuse, the wipers worked. I then push for the wiper fluid, and then the fuse blew again. What should I do? There has to be a problem somewhere, I just don't know where. If anyone knows a few things to check, please let me know.
Kenny
Old January 5th, 2008, 10:35 PM
shawnpalmer's Avatar
shawnpalmer
Shawn Palmer
1997 SW-Arles Blue
Sounds like a problem with the switch to me. Maybe you should take the steering column apart, and inspect the switch for corrosion.
Old January 5th, 2008, 10:55 PM
artm
Arthur Maravelis
97 SW
Start with less work...
Unplug the wiring at the washer pump. Apply 12V at the pump and see if it works. If not then you're lucky - most likely the pump is at fault.
If it does work, then use a voltmeter on the wiring and see if it's shorted (with a fuse installed).
If not shorted, leave the wiring open and press the switch. If it doesn't blow a fuse then connect a voltmeter at the switch and check it out.
If shorted then fuse will blow. Disconnect at switch and check it out with a voltmeter.
Hope it's not in the wiring.
Any 3rd party windshield wipers? cdnpaul Defender Technical Discussions 36 April 27th, 2008 09:36 PM
Heated front windshield for D-90? blenkush Defender Technical Discussions 5 February 28th, 2005 09:53 PM
P/N for heated windshield switch mgrgpg Defender Technical Discussions 5 November 12th, 2004 08:19 PM
Heated windshield TDI Guy Misc. Chit-Chat 15 November 11th, 2003 05:42 PM
Windshield wipers not functioning properly cdnpaul Defender Technical Discussions 1 November 10th, 2003 02:52 PM
