Windshield wiper arms? - Defender Source
Old December 29th, 2009, 12:17 AM
IPSC_GUY's Avatar
IPSC_GUY
Peter/Lesbo
1983 110, 1985 110, 1993 110...
Should the arms simply "pop" off the splined adapters? When I pull my wiper arms off the glass with the smallest bit of wiggling I can pull the entire arm off. My gut reaction is to glue the arm to the splined adapter. Would this be the wrong thing to do?
IPSC_GUY
SIERRA II ALPHA
Old December 29th, 2009, 12:52 AM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Are you talking about when they are flat against the winshield? Or if you have the arms pulled away from the glass?
If it's when they are flat against the glass, then you have some kind of problem. If it's when they are lifted away from the glass, then it's how they are supposed to work.
-Hans
My oil line fix
My 100k stopped odometer fix
Old December 29th, 2009, 02:43 AM
IPSC_GUY's Avatar
IPSC_GUY
Peter/Lesbo
Sorry I should have been more clear. I meant with the wiper arm pulled out away from the glass, I can, fairly easily disengage the wiper arm and pull it free. So that is the way they are supposed to work?
I thought mine were worn out or something. I took the splined adapters off and sand blasted the rust off of them and then gunkoted them for corrosion resistance.
IPSC_GUY
SIERRA II ALPHA
Old December 29th, 2009, 02:51 AM
Hans's Avatar
Hans
Hans Haase
Yep, you're fine. They have a bit of a clamping mechanism in there at the bottom. When you pull them away from the glass, it releases the clamp.
But don't think you wasted your time by blasting the adapters clean. Eventually you may want to remove the arms for some other reason, and will be thankful that they actually come off! Very common for them to be siezed in place.
-Hans
My oil line fix
Old December 29th, 2009, 06:40 AM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
mine were siezed I had to drill them out....
Old December 29th, 2009, 06:50 PM
IPSC_GUY's Avatar
IPSC_GUY
Peter/Lesbo
-Hans
So basically I got luckey huh? Ohhhh I figger that any time spent making ANYTHING on a Defender Rust Proof is time WELL spent.
IPSC_GUY
SIERRA II ALPHA
Old December 29th, 2009, 07:35 PM
smob's Avatar
smob
Steve
'97 Arles Blue SW #2131
IPSC_GUY
SIERRA II ALPHA
Oddly enough, my right wiper arm came off the adaptor, and both connecting points were stripped and rusty. Just ordered the arm (22 bucks) and the adaptor (11 bucks) from RDS, in case you were wondering about replacement cost.
-Ren Ching
Old December 29th, 2009, 09:55 PM
61rover's Avatar
61rover
John Crouse
Had to drill out both of mine. What a pain in the a**.
Put new adaptors on and just ordered a spare set just to have.
Locating the rear wiper pepstein Defender Technical Discussions 0 April 2nd, 2005 09:56 AM
Wiper Blades going haywire... arbik Defender Technical Discussions 4 February 22nd, 2005 11:07 PM
P/N for heated windshield switch mgrgpg Defender Technical Discussions 5 November 12th, 2004 08:19 PM
bulkhead and wiper stud fitting problem mattdh Defender Technical Discussions 3 April 2nd, 2004 09:42 AM
Heated windshield TDI Guy Misc. Chit-Chat 15 November 11th, 2003 05:42 PM
