windshield washer/tire carrier - Defender Source
Old July 4th, 2010, 01:14 PM
TexasD-90's Avatar
TexasD-90
Martin Spencer
1994 D-90
I have been searching, and can't find a good answer to my questions.
My windshield washer is not working. Is there an inline fuse somewhere on the wireing? Is there a fuse for it period? I don't hear a motor trying to run at all when I turn on the windshield washers.
The other question is about the tire carrier. The stock rear carrier makes a ton of noise off road. What is the down side to putting the spare on the hood, and doing away with the rear carrier? Is there anything I can do to get the rattles out of the stock carrier?
That is why it is called a short cut. If it was easy it would just be "the way."
Old July 4th, 2010, 03:51 PM
The fuse is in the main panel before the switch.
Hood mounted tires are hard to see over. When they were 2" wide tires, it was not so bad, but with real tires, it is a large PITA. Maybe your bushings are worn out.
carrier, tire, tire carrier
Safari Gard Tire Carrier Joe P For Sale - Parts 10 November 8th, 2005 06:31 PM
Tire carrier problem - bad threads Antonios Defender Technical Discussions 4 May 7th, 2005 09:15 PM
Mantec Tire carrier Installation Questions Eric Siepmann Defender Technical Discussions 6 November 21st, 2004 01:42 PM
P/N for heated windshield switch mgrgpg Defender Technical Discussions 5 November 12th, 2004 08:19 PM
