Windshield sprayer options - Defender Source
Old March 14th, 2007, 10:00 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
Any suggestions on new windshield sprayers? I keep breaking the one off under the windshield and in is such PITA to get to. I was thinking about a splitter and tubes running to the wipers, then have a sprayer attached at the end of the tubes on the wipers. anyone know of any kits out there?
Old March 15th, 2007, 12:36 AM
artm
Arthur Maravelis
97 SW
I think the goal is to get them further away from the windshield for better coverage. I would drill a couple holes on the hood and install a dual spray unit (two sprayers with two holes each) from any car.
Then you can run the tubes straight to them under the hood and not through the dash. I had the tube disconnect from mine inside the dash once and it sure made a mess - also a pain in the ass to reconnect (through the ashtray).
Finally, if you go to a junkyard you can get the sprayers, tubes and heater elements from a setup that has them. Cheap and no more frozen lines!
Old March 15th, 2007, 12:56 AM
D90user's Avatar
D90user
steve
Good call on the junk yard Art. Heated lines uh?... this may end up being the fanciest thing on my rover
I kind of like the idea of running them on the wipers, I have seen other cars with that setup it seems to work with the low pressure I'm dealing with. Plus I think it will be easier.
I'll post back on what I figure out.
Old March 15th, 2007, 01:05 AM
artm
Arthur Maravelis
97 SW
1. Putting them on the hood eliminates unsightly external tubing.
2. Assuming freezing is an issue, you will really appreciate heated lines especially in a Tdi. I did notice you're in Nevada...
3. I do not have low pressure with my Tdi setup.That can easily be fixed with a better pump.
4. You can even get one sprayer, mounted in the center. I prefer two in case one craps out. Considering they'll be non-LR parts the odds of that happening are remote but a dual setup sure would dump a lot of spray. I always appreciate my Corolla for this!
Old March 15th, 2007, 01:11 AM
D90user's Avatar
D90user
steve
Your speaking my language Art... becoming convinced... change the pump huh...started as a cheap easy fix now moving in to high pressure pumps....going to the pick and pull in the morning.
Old March 15th, 2007, 01:15 AM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Of course you could get Genuine LR heated ones but they'll probably leak!
Personally I don't like the sprayers on the wiper arm, but I guess its personal opinion. For one, they don't tend to properly wet the windshield BEFORE the wipers wipe it, which can cause scratching.
Old March 15th, 2007, 02:43 AM
ScottYates's Avatar
ScottYates
Scott Yates
94 D90 #639, Yellow
Well maybe one of you will know if this is normal. Mine work but are basicly streams like what would come from a garden hose. Plenty of pressure but the stream doesn't fan out at all. Is this another case of incredible LR engineering or am I needing a part? The nozzles?
Some people are like a slinky... not really good for anything, but you still can't help but smile
when you shove them down
the stairs.
Old March 15th, 2007, 02:58 AM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Probably typical. Even the new LR3's is like that! It really bugs me too! My Jeep at least nicely coats the window!
Hey! There you go. I don't think they're heated, but the ones off the '99-'04 Jeep Grand Cherokees might make a nice mod for you.
Old March 15th, 2007, 10:06 AM
paulb's Avatar
paulb
Paul / Boultbee
1994 D-90, Green #1576
Looked at mine last week - tubes are gone! Heated lines are not needed here in Southern Cal. but the vermin have eaten (well nibbled) the tubes. I was wondering how to go about fixing them. So, in the engine bay, if I cut the hose where it enters the firewall that's kosher. Then rerun a sytem. Without having really looked yet, the pump for pressure - in plain sight and a swap out deal with somethiong from the junk yard??
Old March 15th, 2007, 10:30 AM
artm
Arthur Maravelis
97 SW
Scott,
Yes, I think the LR ones do not fan. They don't on both my trucks. That's why I noted teh replacements with two holes each.
Paul,
You don't need a wholesale swap, unless you want to. Just get a plastic tube connector and splice them together. First blow into them and see if air comes out the sprayer. This will save you the trouble of disconnecting/reconnecting nder the dash.
If you need to work under the dash I was able to reconnect the tube at the sprayer head by working through the ashtray hole. A pain in the ass. Apparently my sprayer was blocked and the pressure built up and popped the tube out of its WHIMPY clamp.
Old March 15th, 2007, 10:46 AM
nas110_300tdi
nas110_300tdi
NAS D110
I just found this site where they did a wiper mod: http://www.reedx.net/landrover/mods/wipers/index.htm
Old March 15th, 2007, 11:04 AM
artm
Arthur Maravelis
97 SW
Geez, a whole lot of work for minimal gain. So, you end up with three arcs of spray waiting for gravity to do its work before the blade starts wiping?
Plus, unsightly tubes, tie wraps and two holes in your bulkhead. A lot of over-engineering here!
The beauty of the two-hole sprayer is obvious: you can point each hole to a location on the windshield, covering a larger area.
Don't forget: you can even use a REAL fan sprayer from any modern car, not just the simpler two-hole job. That should satisfy anyone.
Two holes on the hood, pop in your sprayers and connect 'yer tubes. Simple, cheap and looks stock.
Old March 15th, 2007, 11:06 AM
nas110_300tdi
nas110_300tdi
NAS D110
Good point...I don't like the REEDX wiper mod either...just putting it out there for other people to check out - get some ideas flowing. Visuals are always nice, even for bad ideas.
Old March 15th, 2007, 05:41 PM
COSteve
Steven Reed
93 Defender 110 - #107
Is there a way to make the current lower nozzle spray a more " flat spray" vs. the stream pattern?
If a you go with new hood mounted nozzles, is there a preferred tired and true make and model out there? Heated or non heated.....
I agree, the two pinpoint streams are a terrible!
COSteve
Old March 15th, 2007, 06:05 PM
artm
Arthur Maravelis
97 SW
Folks...
Let's not get overly deep here...any nozzle will do. Just find one with the look you want, dual hole or fan spray and that's it.
There is no rocket science here.
Old March 15th, 2007, 06:19 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
I have a spare new one if you are interested..
Legend in My Own Mind.
Old March 15th, 2007, 07:43 PM
devinchi's Avatar
devinchi
Tim Brown
'95 D90 ST '99D2
If you decide to scavenge a whole setup, I will recommend one from a modern style Saab 9-3 or 9-5, they have 3 nozzles on the hood and are wicked high pressure, I was actually scared the 1st time I used them o my wife' s saab.
I got your JEEP thing, now it hurts when I pee!!
Old March 15th, 2007, 08:48 PM
D90user's Avatar
D90user
steve
I want to keep this simple... I have decided not to change the pump, just the nozzle. there is a geometry issue with many sprayers because of the flat hood and windshield and the roll bar. I also want to keep the use of my hood spare mount. I found a nozzle from a late model dodge ram that may work. Also late 80's wranglers seem to have the right angles. I'll post up when I figure it out.
Randy- I may end up taking you up on the nozzle if thsi becomes too much of a bitch...this is the 4th time I (or a friend) have broken it off and I get so pissed.
Old March 15th, 2007, 10:59 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
I have one too. Infact, I have the whole setup if someone wants it. Of course, the pump motor is 24 volts, so it doesn't work all that well. If your going fast enough, some water does manage to hit the windshield.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old March 18th, 2007, 01:29 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
No prob. let me know
Options, what are they? Britt Easterly Defender Technical Discussions 8 May 11th, 2005 10:26 AM
Heated front windshield for D-90? blenkush Defender Technical Discussions 5 February 28th, 2005 09:53 PM
P/N for heated windshield switch mgrgpg Defender Technical Discussions 5 November 12th, 2004 08:19 PM
exhaust- options Nigel Defender Technical Discussions 11 October 20th, 2004 10:34 PM
Heated windshield TDI Guy Misc. Chit-Chat 15 November 11th, 2003 05:42 PM
