Windshield sprayer options - Page 2 - Defender Source
Old March 19th, 2007, 10:40 AM
Tawayama's Avatar
Tawayama
Michael Slade
No Land Rovers
VDO makes a great replacement washer pump/tank system. Cool thing is the pump is a direct drop-in for the Rover washer tank. dunno about the electric connector, but the VDO kit comes with it's own plug that you could splice into your existing harness. The pump is not offered on it's own, but the smaller tank system isn't that expensive, and you get all of the wiring, tubing, etc... VDO also makes some nice jets, but they are quite expensive, ironic considering how reasonable the washer pump is.
I am using the two seperate stock washer jets that mount right under the wiper blades, one under each blade. I get TONS of spray, no problems.
If you are looking for some jets that will mount on the hood, some RRC jets would work well, are pretty flat on the base, etc...only problem is the hole shape is very funky.
Michael Slade
www.tawayama.com
Options, what are they? Britt Easterly Defender Technical Discussions 8 May 11th, 2005 10:26 AM
Heated front windshield for D-90? blenkush Defender Technical Discussions 5 February 28th, 2005 09:53 PM
P/N for heated windshield switch mgrgpg Defender Technical Discussions 5 November 12th, 2004 08:19 PM
exhaust- options Nigel Defender Technical Discussions 11 October 20th, 2004 10:34 PM
Heated windshield TDI Guy Misc. Chit-Chat 15 November 11th, 2003 05:42 PM
