Windshield Installer in Houston? - Defender Source
Old January 15th, 2009, 08:34 AM
mikeybob2@msn.com's Avatar
mikeybob2@msn.com
Michael Sabanovich
1994 Defender 90 #1880
Does anyone know of a good windshield installer in the Houston area? I got my new winshield from AB and rubber from Safari but after reading the posts on installing, I think I'd screw it up. Any help is appreciated.. Thanks, Mike
Old January 15th, 2009, 08:51 AM
landrovered's Avatar
landrovered
S. Smith
72 Series III 109 Diesel
It is harder to boil water than change a Defender front windscreen DIY!
Old January 15th, 2009, 10:34 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
did you just see my post on the install? IT was really easy
Legend in My Own Mind.
Old January 15th, 2009, 10:44 AM
mikeybob2@msn.com
Michael Sabanovich
Yes I did, thanks.. It does sound easy and I have the cord, etc.. I'll give it a try if I can get that "extra set of hands to help" All of my buddies are afraid to mess with glass...lol
Old January 15th, 2009, 10:54 AM
landrovered
S. Smith
Normally I would agree with them but this is as easy as it gets.
You have a new gasket so I recommend you take a razor knife, run it around the edge of the old window seal cutting the outside of the old gasket off. The old window will pop right out. Clean the opening and put a bit of KY on it.
Put the new gasket on the new window, put the cord in the gasket. Position the window over the hole. Get it as snug as you can without pushing too hard on the glass.
Pull the cord out so that the gasket lip goes over the window frame. Windex the window and you are done.
windshield weather stripping advice... Grover Defender Technical Discussions 0 March 4th, 2006 02:28 PM
Houston Customs Broker Needed pcarey Defender Technical Discussions 3 January 12th, 2006 10:36 PM
Heated front windshield for D-90? blenkush Defender Technical Discussions 5 February 28th, 2005 09:53 PM
P/N for heated windshield switch mgrgpg Defender Technical Discussions 5 November 12th, 2004 08:19 PM
Heated windshield TDI Guy Misc. Chit-Chat 15 November 11th, 2003 05:42 PM
