windscreen glass & door skins - Defender Source
Old March 9th, 2004, 01:16 AM
mattdh's Avatar
mattdh
Matt Hurst
has any one taken the glass out of the windscreen frame?is it possible to do with out breaking the glass or tearing up the seal?could you give me details on how to do this?-----i saw some one galvanized the frames to there roll up window doors, how do you remove the door skin frome the door frame? i have the doors off and every thing off the door.
Old March 9th, 2004, 01:23 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
You cannot galvanize them. They are aluminum. I don't know what you saw, but just take a magnet to them and you can see for yourself.
You can remove the seal from the windscreen by first spraying down both sides liberally with water/soap and starting at the split very carefully easing it out. Or just shatter the glass and pull it right off.
Old March 9th, 2004, 01:44 AM
mattdh's Avatar
mattdh
Matt Hurst
chris- the skin of the door is aluminum but the frame(or insides of the door)is steel
Old March 9th, 2004, 02:41 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Totally--I completely misread your post. I thought you were going to galvanize the door/windscreen as I combined both the top and the bottom of your post while swigging some nice IPA. Yummy. At least I hope I answered your windscreen question! ;-) Someone within the last year had a post about replacing the aluminum skin on the door with stainless steel--you might try a search on that.
Also, and something that I am currenly looking at, you may consider reinforcing the vertical members of the doorframe so that the flex is less so the top of the door stays shut better.
best regards,
c
Old March 9th, 2004, 03:23 AM
kellymoe's Avatar
kellymoe
kevin
defender 130
Matt,
About two months ago I rebuilt the driverside door frame on my truck. The window is easy to remove with no damage.
Old March 9th, 2004, 05:23 PM
mattdh's Avatar
mattdh
Matt Hurst
kevin-i got your pics,i really like the color of your defender-both look great!how do you remove the skin of the door
Old March 9th, 2004, 06:09 PM
kellymoe's Avatar
kellymoe
kevin
defender 130
I took the door off. Removed the interior panel. Removed the glass. I did not remove the skin from the frame. I had alot of rust on the outer steel frame. I peeled back the aluminium skin and used a Sawzall to remove the rusted out section. Took square tubing of the apropriate size and rebuilt the frame. Kept the original skin.
Old March 9th, 2004, 06:44 PM
You cant pull a skin and re-use it.
This book has instruction on how to do it:
Defender Book on Amazon
Old March 9th, 2004, 08:23 PM
kellymoe's Avatar
kellymoe
kevin
defender 130
I reused it. Doesn't look that good but I reused it. My truck is a 20 footer. Looks good from 20 feet.
door, glass
Price drop on heated windscreen glass Overlander Defender Technical Discussions 7 August 14th, 2006 10:47 AM
POE Lift Gate and Glass TDI Guy For Sale - Parts 11 May 25th, 2006 05:02 PM
ST windscreen frame used with SW top? Chris Cox Defender Technical Discussions 6 September 28th, 2004 06:21 PM
Windscreen ideas Mike Hippert Misc. Chit-Chat 40 July 9th, 2004 02:38 PM
bulkead corrosion near windscreen hinge Neo Defender Technical Discussions 2 March 8th, 2004 01:54 PM
