Window Seals - Defender Source
Old January 31st, 2012, 09:58 AM
UT-Rider's Avatar
UT-Rider
Sean
1997 D90
Window Seals
Trying to figure out if I need to remove the "Safari" window on my SW to replace the seals. Nobody has the seals in stock or can get them either. Any ideas or suggestions?
Old January 31st, 2012, 10:30 AM
Do you mean the felt that stops the windows rattling?
I got mine from lrseries.com
You do need to take the frame out .... remove the rubber .... drill out the rivets .... remove screws in the frame ... replace felt ....
It doesn't take long.
Old January 31st, 2012, 10:34 AM
I figured he was talking about the safari windows in the roof. Sean, where have you tried so far?
Old January 31st, 2012, 10:47 AM
UT-Rider's Avatar
UT-Rider
Sean
1997 D90
The rubber is a little worn/rotted out. I'm trying to replace that. I figure I'll also replace the felt as well.
------ Follow up post added January 31st, 2012 10:49 AM ------
Rovers north. Atlantic British only carries the windshield seal.
Old January 31st, 2012, 11:09 AM
I think the fixed roof windows are the alpine windows ...
------ Follow up post added January 31st, 2012 11:17 AM ------
also ... welcome to the board and show us your truck!
Old January 31st, 2012, 11:33 AM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
Justin at Lucky 8 can get you anything you could possible need. Trust me, he has pulled off a miracle for me more than once.
Old January 31st, 2012, 11:54 AM
http://www.defendersource.com/forum/...ht=window+felt
Old January 31st, 2012, 11:57 AM
UT-Rider's Avatar
UT-Rider
Sean
1997 D90
Thanks, just got off the phone with him. $15 for aftermarket windshield seals.......$120 OEM.
"Life's too short not to go big" - JB
Old January 31st, 2012, 11:59 AM
now I'm really confused.
Old January 31st, 2012, 12:05 PM
UT-Rider's Avatar
UT-Rider
Sean
1997 D90
Thanks for the link. I was talking about the roof "oval" windows. I'm also replacing the windshield seals.
Old January 31st, 2012, 01:39 PM
alpine windows.
are you changing them yourself?
------ Follow up post added January 31st, 2012 01:39 PM ------
I think they have a section for that on craigslist ...
Old February 1st, 2012, 08:15 AM
UT-Rider's Avatar
UT-Rider
Sean
1997 D90
[QUOTE=leastonce;326555]alpine windows.
Never hurts to try! I sat in the garage bay a long time last night pondering my approach.
I think we have a doppelganger in the NYC area.........
Old February 1st, 2012, 03:24 PM
[QUOTE=UT-Rider;326726]
alpine windows.
my mate phil also has the same truck ... we should have a NYC white 95 SW meetup ...
Old February 1st, 2012, 03:32 PM
Jason you haven't been to a meetup in years - don't kid yourself!
Old February 1st, 2012, 03:39 PM
as the creator of the original thread ... I own the meetup!
Old February 1st, 2012, 05:05 PM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
The Alpine window instal is not that bad once you get the hang of it, I just did mine. A good sized flat screw driver and some dish soap on the filler strip will do the trick. The hardest part is getting the window in the seal once you have it in place. You should really have another person there to help hold the window so it doesn't pop out while you are trying to stuff the filler in
Old February 2nd, 2012, 11:32 AM
Skeena river rover's Avatar
Skeena river rover
jeroen
1997 300 TDI 110
I just did mine and it was a bitch. I bough the after market ones and they are some how very stiff. I tried and was not able to fit the window back in. If you leave the filler out no problem with filler no way! So i have 2 options buy the OEM ones, they are softer! or let a pro do it!
Good luck!
Old February 2nd, 2012, 11:35 AM
soften seals in a bucket of boiling water
Old February 2nd, 2012, 02:20 PM
Skeena river rover
jeroen
1997 300 TDI 110
That might be possible! did not tried it. Will do the next time! Thanks for the tip.
Old February 2nd, 2012, 03:38 PM
You put the rubber around the window. put a piece of cord around the outer rubber channel. work the bottom edge of the rubber into the opening. Keeping pressure on the outside, have a helper pull the string from inside which will seat the entire rubber channel in the opening. Next, using the special tool, insert the locking strip all the way around. I like a lob of silicone in the joint where the ends meet.
This rubber channel is nothing special. you can get it from glass shops and many online stores.
seals, window
Still possible to get all the window seals for the D90 fiberglass top? Neil McCauley Defender Technical Discussions 2 February 3rd, 2011 02:35 PM
Alpine Window Seals bjf Defender Technical Discussions 14 January 3rd, 2010 06:30 PM
Fiberglass Hard Top Window Seals Grover Defender Technical Discussions 4 April 25th, 2009 01:56 PM
Front Vent Flap Seals Flagg Defender Technical Discussions 14 February 20th, 2006 05:14 PM
Window seals for Fiberglass Hard Top (wanted) wildenbeast Wanted 1 November 1st, 2005 10:55 AM
