window regulator handle? - Defender Source
Old November 20th, 2004, 03:31 PM
snuffer's Avatar
snuffer
Randy Black
'95 D 90 SW
How do you get the window regulator handle off so that you can remove the interior door panel?
It's a '95 D90 SW. All of the info I have found shows a trim piece that prys off with the screw underneath.
My handle does not have the pry out trim piece but is solid with no access to the screw?
Old November 21st, 2004, 12:09 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
between the door panel and the back side of the handle, you will notice a spring steel clip, kind of like a "U" that goes around the cylinder that is visible in that little space. Pry this out. When re-installing, replace this "U" on the handle before fitting back onto the regulator stud (that will come out from the door panel) and then "smack" it back onto the door. This makes sense when you see it, because the regulator portion that is attached to the door is pointy and will separate the U clip as you "smash" it back on. Best I can describe.
Old November 21st, 2004, 10:22 AM
snuffer's Avatar
snuffer
Randy Black
'95 D 90 SW
Thanks Chris, I'd sure like to find a complete manual for my Defender. Nothing I have found is complete and few seem to be for the '95 NAS model.
Thanks again
window
FOR SALE - Set of Used Oil Cooler hoses / window studs eric_besore For Sale - Parts 10 August 31st, 2005 02:18 AM
Window removal 1/2 way there Help!! paulb Defender Technical Discussions 2 May 11th, 2005 04:13 PM
shattered sliding window on d-90 prospector Defender Technical Discussions 5 January 16th, 2005 10:41 PM
'97 SW window handle crank J4hand Defender Technical Discussions 2 August 8th, 2004 08:51 PM
Soft Top Side Window Bar boshea Wanted 2 June 18th, 2004 08:14 PM
