Window Rattle Solved - Defender Source
Old March 27th, 2007, 05:08 PM
Raider's Avatar
Raider
Adam Knox
95 ST AA Yellow
I am planning a little road trip and decided I had to do something about the rattle in the windows on my soft top. It was the glass in the door tops making the noise as opposed to the door top itself. I ordered some glazing felt from RN, one for each door @ $30 a piece, before I realized it took 4 pieces per door. As $120 per door seemed a little steep to fix an annoying little rattle, I looked elsewhere for some felt. I found a roll of medium density 3/4" wide x 1/8" thick x 25' long for only $10 from Duro-Felt in Little Rock. Check this link for the felt http://www.durofelt.com/image_17.html. I used the grey. JimC's instructions in this thread http://www.defendersource.com/forum/...ead.php?t=7172 were terrific and accurate. The fix didn't take long, and now the windows are rattle free. The glass is pretty tight in there right now and takes a little more effort than usual to open and close, but I'm sure the felt will compress a little over time. Just thought someone else might enjoy saving a little money on the felt and fix an annoying problem.
Old March 30th, 2007, 02:06 PM
jimngo's Avatar
jimngo
Jim Ngo
1994 D90 #80
I used little felt sticky pads you can find at any crafts store.
rattle, window
Window rattle D90user Defender Technical Discussions 4 February 2nd, 2006 11:23 PM
FOR SALE - Set of Used Oil Cooler hoses / window studs eric_besore For Sale - Parts 10 August 31st, 2005 02:18 AM
shattered sliding window on d-90 prospector Defender Technical Discussions 5 January 16th, 2005 10:41 PM
'97 SW window handle crank J4hand Defender Technical Discussions 2 August 8th, 2004 08:51 PM
Window rattle ? Hammertime Defender Technical Discussions 3 April 13th, 2004 04:08 PM
