Window Question on 2 Piece Rear Door Build Up & - Defender Source
Old August 24th, 2013, 01:22 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
When we bought our 110 2 door, it came wilt a full length long cab hardtop with rear standard door.
I converted it to a pickup and cut the rear door in half.
The machine shop made me a 1/4" steel strip with chamfered edges that matched the shape of the series IIA door top divider strip. I welded the strip onto the rear door bottom and cut and welded 2 of the IIA divider strips together and pop riveted it to the top of the door bottom.
Then the shop made another metal strip for the top portion of the door with 3 studs so the 2 pieces can bolt together after the corresponding holes were drilled.
It turned out nice and does not flop around.
Since there is no rust except for the stains from the rear tire mount, it will look good with a fresh coat of paint.
Now for the question.
Years ago we use to be able to get the black sticky window putty, but have been unable to locate any listings for it with web searches and checking the RN web site.
Any suggestions as to where to get the stuff other than a local auto glass and window shop which we will check Monday.
ID:	78210   Click image for larger version
RDavisinVA
Old August 24th, 2013, 01:40 PM
No, I think he is looking for dum dum. It is 3M product and comes in strips.
Old August 24th, 2013, 01:41 PM
Not quite sure what you're looking for but I immediately thought of 3M.
3n has this stuff great for sealing between body panels
http://www.amazon.com/gp/aw/d/B004M4KWXA
And
http://m.autozone.com/autozone-mobil...25y6?id=464397
Old August 24th, 2013, 02:44 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
That's it
RDavisinVA
Old August 24th, 2013, 03:15 PM
Guess we all love that stuff!!!!
Old August 24th, 2013, 04:54 PM
323jamie's Avatar
323jamie
jamie
83 D110 RHD 300tdi Disco conversion
The Twinkies are here the best come back in the History of EVER
Old August 24th, 2013, 11:52 PM
I heart it too.
The uses on a land rover are innumerable!
door, rear door, window
Station Wagon rattling rear window fix Davis Defender Technical Discussions 7 March 10th, 2012 11:50 PM
Help installing rear window glass PCRover Defender Technical Discussions 7 December 25th, 2007 02:44 AM
Rear Bestop pass. window UpnOver Wanted 0 August 13th, 2005 02:26 PM
Bestop Rear Window MDS Wanted 2 August 22nd, 2004 12:11 PM
Rear Window Heater Help mwmcgehee Defender Technical Discussions 0 August 21st, 2004 01:40 PM
