Winch wiring question - Defender Source
Old January 11th, 2004, 12:27 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
I am getting a Rockware bummper and am going to mount my XD9000i to it. My question. Is there a place under the hood that I can run the power cables from the winch to? Or do I need to get extention cables to run it to the battery?
Jimmy Buffett
Old January 11th, 2004, 02:04 PM
scoloco's Avatar
scoloco
'94 D90 ST
I finished up getting longer cables from a welding shop to hook up my XD9000i.
I did see a writeup somewhere using a switch of some sort so the winch was not always wired up. In this case the switch was in the engine compartment, probably using the stock winch power leads, and extensions went the rest of the way to the battery compartment.
Old January 11th, 2004, 03:45 PM
flippedrover
Tyler
'94 D-90
Thanks. Where did you run the cables?
Jimmy Buffett
Old January 11th, 2004, 08:18 PM
ronward's Avatar
ronward
Redsrover
None - sadly
My ARB came with extended cables for the Warn I already had. Ran them under the rad up into the bay just under the power steering fluid reservoir, around back of the drivers side shock turret cover and then down along the frame to the rubber grommet into the battery box. Tied it all down with zip ties.
Old January 11th, 2004, 09:20 PM
flippedrover
Tyler
'94 D-90
Cool. Thanks
Jimmy Buffett
winch, wiring
Winch Wiring Question Stmpede Defender Technical Discussions 62 May 5th, 2014 12:08 AM
Custom wiring question Doug Defender Technical Discussions 7 December 15th, 2004 02:43 PM
Newbie Winch Question Joe P Defender Technical Discussions 2 November 28th, 2004 01:30 AM
Wiring question - bypassing ECU for rear defogger dmarchand Defender Technical Discussions 8 September 30th, 2004 11:21 AM
Winch Bumper Question mgrgpg Defender Technical Discussions 17 February 21st, 2004 10:48 PM
