Winch Wiring Question - Page 3 - Defender Source
Old October 26th, 2010, 08:57 AM
kevkon's Avatar
kevkon
kevin
1994 D90 300tdi #730, SIII 88
Originally Posted by o2batsea View Post
I don't know how into overkill you are, but as for me, I treat an off road vehicle like a boat. As much as possible I use marine grade wiring and terminals as well as wiring protocols.
First off, let's discuss the ground. I dunno what Winch Guy is talking about burned up brake lines but whoever owned that truck had some seriously fu*ked up wiring that was likely not related to winch installation. A frame ground is just fine and dandy as long as you are sure the connections are clean and tight. My preference is for a separate ground bus bar with a cover. These have 5/16ths tinned studs and can carry 600 amps. You can put several grounds on this type of bar and the cover keeps tools and stuff from causing arcs.
I also prefer marine grade cables. These are made of stranded tinned copper with oil and fuel resistant cover that also have a fire rating. A line as small as grade 8 will carry the loads of a winch motor but the resistance is pretty high. I wouldn't use anything smaller than a 0 for winch cables even though you probably don't need it. Again, overkill.
In order to keep moisture out of the cable strands, I use a tinned copper lug that is crimped (never use solder) and covered with an adhesive lined shrink tube to seal up the gap between the cable cover and the lug. This assembly will withstand dunk after dunk and will not get water in it. Finally I use proper sized boots to cover the connector lug on both the ends of the cable to protect from accidental contact. I spray all connections with either Boeshield or Deka Battery Terminal Spray.
Genuinedealz.com is my choice for on line purchasing. They have always had my order on my door within two days and when I once had a problem they made it right the next day.
I do the same. West Marine and Jamestown are great sources. There isn't much point in worrying about cable size if the terminations are not up to the task.
Old February 10th, 2014, 11:40 PM
RickM
Rick Mabus
95 D-90 ST
Hey guys. Anyone have a recourse for dual cable mount battery terminals? Ones that can handle the amp draw and size? Thanks.
Old February 11th, 2014, 05:34 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Mil-spec terminals work well.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old February 11th, 2014, 06:14 AM
I like the cast bronze terminals that are tinned. They have a stud for attaching multiple cables. Not a big fan of cast lead, which stretches (loosens) over time. You can get them at a boating store
Old February 11th, 2014, 09:57 AM
RickM
Rick Mabus
95 D-90 ST
Thanks for the heads up on that.
Another thought idea. I am installing a warn vr8000. In looking at the sileniod it would appear to me that the electrical stuff is somewhat exposed to the elements. Has anyone ever sprayed down the electrical parts with some of that waterproofing spray material for extra precautions?
Old February 15th, 2014, 11:01 PM
RickM
Rick Mabus
95 D-90 ST
Got my winch mounted tonight. Got the wire (1/0) sourced from a welder supply. Tucked the solenoid under the drivers side. It turned out really good.
Old February 16th, 2014, 05:07 AM
DannyboyUpstate's Avatar
DannyboyUpstate
Danny Harrington
1983 110 3-door
A lot of people spray those older type solenoids with fluid film.
The best option is to swap up to a newer style contactor and ditch the solenoids all together.
I just did that to my M12000. It was reasonably priced.
Old February 16th, 2014, 07:34 AM
Antichrist's Avatar
Antichrist
Tom Rowe
I find the issue with them is people over tightening them.
As long as they are tightened only as much as needed for a snug connection there isn't an issue. Some of mine have been in service for decades and are still working just fine.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old February 16th, 2014, 09:43 AM
Squaretyre's Avatar
Squaretyre
Landan
94 d90
For what it's worth, insulate your positive cable as much as possible. I'm on my second catastrophe from the cable arcing through at rub points and frying something. Finding the arch isn't bad, but where the wires melted together is another mind boggling guess. I've ended up using insulation wrapped at each pinch point.
Old May 4th, 2014, 02:05 PM
Originally Posted by Ren Ching View Post
good idea though it should go without saying to order extra to be safe.
I bought the 1/0 from here:
https://weldingsupply.securesites.com/
showed up within a day or two and I also ordered the lugs, and a cheesy crimper.
Another revival of this thread...
I just bought cable and ends from this place, but I didn't buy the crimper. Does anyone know of a good want to crimp these without a special tool? I don't really want to buy one just to do four crimps.
Old May 4th, 2014, 03:40 PM
jafir's Avatar
jafir
Jafir Elkurd
Originally Posted by Jymmiejamz View Post
Another revival of this thread... I just bought cable and ends from this place, but I didn't buy the crimper. Does anyone know of a good want to crimp these without a special tool? I don't really want to buy one just to do four crimps.
I cannot open the link on my phone so I don't know what crimper is mentioned, but I've got a super cheap hydraulic crimper from harbor freight. It leaks oil like mad, but does an ok job crimping big things. I think it was on sale and I used a coupon.
Maybe someone near you has one of those you could use.
Old May 4th, 2014, 04:09 PM
That would be ideal!
Old May 4th, 2014, 05:36 PM
Forney 57637 Lug Crimping Tool $20
I don't own one but it gets great reviews.
http://www.amazon.com/Forney-57637-L...4SDMKMS1NKHC73
Old May 4th, 2014, 05:47 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
That link earlier in the thread seems to not work. Does anyone have experience with a place I can get custom cables cut to length?
Old May 4th, 2014, 07:08 PM
josh-man's Avatar
josh-man
joshua
82 Land Rover 110 Ex MOD
Id hit up a welding supply shop. They will have red and black welding cable that you can crimp or solder the appropriate terminals to. I did a solenoid relocate on my first disco and that's how I got the wire. Sold by the foot, I'm sure a spot in Burlington/s.burlington exists.
Old May 4th, 2014, 09:03 PM
https://weldingsupply.com
Old May 4th, 2014, 09:12 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Thanks Jimmy, now deciding what size to go with..1/0 seems pretty large....
------ Follow up post added May 4th, 2014 09:20 PM ------
Ended up ordering the 1/0....hopefully the correct lengths
Old May 4th, 2014, 09:36 PM
I ordered 12' of 1/0 in red and in black. I hope I don't need the other 6"
Old May 4th, 2014, 09:39 PM
You will IME.
Old May 4th, 2014, 09:45 PM
jafir's Avatar
jafir
Jafir Elkurd
12 feet of each color or 12 feet total?
winch, wiring
Custom wiring question Doug Defender Technical Discussions 7 December 15th, 2004 02:43 PM
Newbie Winch Question Joe P Defender Technical Discussions 2 November 28th, 2004 01:30 AM
Wiring question - bypassing ECU for rear defogger dmarchand Defender Technical Discussions 8 September 30th, 2004 11:21 AM
Winch Bumper Question mgrgpg Defender Technical Discussions 17 February 21st, 2004 10:48 PM
Winch wiring question flippedrover Defender Technical Discussions 4 January 11th, 2004 09:20 PM
