winch wiring - Defender Source
Old April 9th, 2015, 10:28 PM
CaptMidnite
Daniel Choi
94 NAS Defender 90 ST
winch wiring
For a D90 with the battery located under the seat box, online research shows the winch wiring length to be about 3m or 10 ft?
Does that seem right? I used a piece of twine and it seemed a foot or two longer.
Also, what gauge wire? The sources I looked up seem to be using UK electrical standards.
Old April 9th, 2015, 10:56 PM
No idea about length. I used 2/0. IIRC you can probably do 1/0 but I would not go smaller.
Old April 10th, 2015, 04:21 AM
aka rover's Avatar
aka rover
ed angel
95 D90
10ft is about right if you run down the frame rail . It's more like 12-14ft if you run up and over the fender on the left side .
85 D110 3.5 3 DR
Old April 10th, 2015, 07:09 AM
10 feet is too short. at least 13 feet. i recently did my truck and 25 feet was a hair too short to make both ground and power cables. it was super frustrating to cut the right length power cable from 25 feet only to be a few inches too short on the ground side.
Old April 10th, 2015, 07:53 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Just a thought but I have used Jumper cable cords to run the wire. You need to get the HD ones that are #2 wire however. Lowes has a long set that I have used and the length is good. I have found it to be less expensive than just buying the wire. The wire is stranded with a thick coating but I do not know how it will hold up to extended winching. You do have to cut the ends and fix new ends but would have to do that anyway with most wires.
Old April 10th, 2015, 09:02 AM
josh-man's Avatar
josh-man
joshua
82 Land Rover 110 Ex MOD
Originally Posted by CaptMidnite View Post
For a D90 with the battery located under the seat box, online research shows the winch wiring length to be about 3m or 10 ft? Does that seem right? I used a piece of twine and it seemed a foot or two longer. Also, what gauge wire? The sources I looked up seem to be using UK electrical standards.
Hit the welding supply store nearest you for wire. Cheapest you will find as they simply sell a great deal of it.
Old April 10th, 2015, 09:25 AM
IMO, welding wire is better as well. Flexible, oil resistant, heat resistant.
Old April 10th, 2015, 09:32 AM
UnfrozenCaveman's Avatar
UnfrozenCaveman
Keith Armstrong
Various
Get thee to thine local welding supply shop.
Nice flexy 2/0 or 1/0 file stranded copper cable with a substantial insulator...oh yeah, and they'll have cable ends and heat shrink tubing for you too.
No. it won't be as cheap as jumper cables...but then again, it won't be jumper cables....
YMMV
KSS
Old April 10th, 2015, 10:18 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
I used battery cables.
Old September 21st, 2016, 10:39 AM
Reviving an old thread instead of starting a new one........
Is 13 1/2 feet of 2/0 cable the ticket to a successful install? I'm hoping to get this done today if possible.
Old September 21st, 2016, 10:52 AM
speedpin's Avatar
speedpin
Yes but x2 for + and - side
I ran under Rad support, down LH side frame rail then up into seat box, added heater hose at rub points.
~ Semper Fidelis ~
Old September 21st, 2016, 10:58 AM
My bad, 27 feet total.
Old September 21st, 2016, 11:18 AM
speedpin's Avatar
speedpin
You will have a little extra but better than too short. gives you routing options if frame rail isn't appealing..
~ Semper Fidelis ~
Old September 21st, 2016, 11:19 AM
I personally think 2/0 is a waste. It has marginally better current capacity compared to 1/0 and costs more. I would buy 30 feet to be safe. Like Adam said, better safe than sorry.
Old September 21st, 2016, 11:29 AM
speedpin's Avatar
speedpin
I find good value and quality in the welding wire that airgas (welding supplier) sells. They will even refill my powertank.
~ Semper Fidelis ~
Old September 21st, 2016, 11:44 AM
I was planning on having them crimp the ends on at the welding shop.
Old September 21st, 2016, 12:22 PM
I run the entire length of the positive through a conduit made of heater hose. Anything nicking the insulation creates the opportunity for an unexpected welding incident or worse fire. Another suggestion is to use heat shrink with adhesive ie marine heat shrink on the ends to prevent water ingress. Twisted copper, especially large gauge, is prone to "going green" with air and moisture. Making the ends as weather tight as possible is the goal.
Worldwide Land Rover Shipment and Importation Service
Bespoke Restoration & Modification work
Old September 21st, 2016, 03:14 PM
1of40's Avatar
1of40
1of40
that's brilliant
Old September 21st, 2016, 03:25 PM
Originally Posted by 1of40 View Post
that's brilliant
I have moments of clarity
Actually credit where credit is due, Pendy imparted the heater hose idea/wisdom to me, 10 plus years ago.
Miss that guy, hope he's well.
Old September 21st, 2016, 03:34 PM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
Yeah, he kind of dropped off the planet, what ever happened to him??
As for useful info for this thread...
I saw a guy years ago who used Seal Tight Electrical conduit and right angle connectors to run the cables back to his battery box. He drilled holes (now we cringe at this, but 15 years ago not many owners through twice about it) in the seat box to fit the connectors, but its another thought for protecting the cable...
I ran 2/0 gauge welding cable, and put it in a plastic corrugated conduit to protect against chaffing, but the heater hose is probably a more durable solution..
I also updated the cables from the solenoids to the winch motor to larger (1 gauge I believe), fine strand welding cables when I had the original leads made up..
~Scott T.
'95 D-90 ST - AA Yellow
winch, wiring
Winch Wiring Question Stmpede Defender Technical Discussions 62 May 4th, 2014 11:08 PM
Winch/Power Wiring Opinion Wolf Fabrication Defender Technical Discussions 20 June 4th, 2008 09:55 PM
Warn winch wiring diagram TwisteD90 Defender Technical Discussions 4 December 27th, 2006 11:32 AM
Winch wiring in a 90 Doug Crowther Defender Technical Discussions 20 November 15th, 2006 09:14 AM
Winch wiring question flippedrover Defender Technical Discussions 4 January 11th, 2004 08:20 PM
