Winch Solenoid Comparison Question - Albright - Page 2 - Defender Source
Old March 30th, 2011, 11:29 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
Originally Posted by Oxcart13 View Post
Jeff - my intent was to go through it to understand what I had (oil, condition of internals, brake, etc.) and to ensure it was reliable as I had one occasion when it didn't work. WRT to the motor, I decided to replace it and like the defender V8s, it didn't make sense to replace a 4.0 with a new 4.0 when a 4.6 is not that much more in cost.
In my case the motor I have is a 2.5 or something like that...
------ Follow up post added March 30th, 2011 11:32 AM ------
Originally Posted by cgalpin View Post
Jeff, the solenoids are like new and the motor worked fine when I tested it. Quit trying to come up with ways to waste time and money on it - I did so already
Galpin, hush! I'm not questioning whether or not everything works...it's more a question of whether I should change/replace parts while the winch is still in 50 pieces. Plus, (as you know) I am planning to relocate the solenoids somewhere. The Albright seems to be an upgrade on the electronic side but at the same time is considerably smaller and therefore much simpler to relocate!
Plus, you know my style by now...I like wasting money!
Old March 30th, 2011, 12:00 PM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
If you are looking to do some upgrades here is a website you really dont/should look at. Gigglepin4x4
Not sure if Gigglepin sells this but I do know of a company that sells an adapter so that you can put two motors, end on end onto the 8274.
I think this is the motor you are looking for, 6.8hp
Old March 30th, 2011, 12:04 PM
TS888's Avatar
TS888
Tony Sims
1984 110
Ah Gigglepin, home of winches worth more than my truck...
Tony
1984 110 "Smokey" (sold)
Old March 30th, 2011, 10:18 PM
dsh12
Daniel Hayes
1994 Defender 90 Soft Top
Originally Posted by o2batsea View Post
I'm with Tom. 4 big honkin Cole Hersee continuous duty solenoids. The ones that are epoxy coated. Dunny done.
What part number?
Dan
94D90 NAS 3.9 LT77 LT230T Soft Top
There are no guarantees expressed or implied of the accuracy or correctness of the contents of this message, and the Author is not liable for the taking of any action in reliance upon the contents of this message. As always, do your own research. To the extent that opinions are expressed in this message, they are not necessarily the opinions of the Author.
Old March 31st, 2011, 07:31 PM
dsh12
Daniel Hayes
Originally Posted by Antichrist View Post
I've been using 4 200amp continuous duty solenoids in the typical 8274 setup.
I've been considering Albrights, but it would worry me using those. At only 180amp it's down 30% duty cycle and none of my electric winches draw less than 300amps at full load.
Tom, who is the manufacturer and what is the part number of the 200amp continuous duty solenoids?
Dan
Old March 31st, 2011, 08:05 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Cole Hersee
24143
http://www.colehersee.com/pdf/master_cat/e_solenoid.PDF
I also use these disconnects:
http://www.colehersee.com/pdf/hot_fe...0AMDisconn.PDF
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old March 31st, 2011, 10:47 PM
dsh12
Daniel Hayes
For amp values check out the performance specs for the XD9000i at the bottom of the page:
http://www.warn.com/truck/winches/src/XD9000i.shtml
------ Follow up post added March 31st, 2011 10:58 PM ------
Will the CH-24143 fit in the XD9000i solenoid compartment-its a tight fit? The replacement solenoids sold by Warn have top mount terminals. However, the old rusted solenoids I pulled out of my XD9000i were side mount - they looked very similar to starter solenoids found on older cars.
Dan
Old March 31st, 2011, 11:25 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Sorry, no idea.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old April 3rd, 2011, 08:07 PM
dsh12
Daniel Hayes
With the factory replacement solenoids for the XD9000i (see below), how long can it safely pull before it burns up - what should be the pull/rest cycle (lets say an average pull yourself out of the mud hole scenarios)?
http://www.amazon.com/WINCH-SOLENOID...=pd_sbs_auto_1
http://www.wanderingtrail.com/Repair...s/DSC04765.jpg
Dan
ht, winch
Newbie Winch Question Joe P Defender Technical Discussions 2 November 28th, 2004 01:30 AM
WARN 8274-50 Winch, THE ULTIMATE!!! RedRhinoProducts For Sale - Parts 0 September 28th, 2004 08:18 AM
Moving winch solenoid howellm70 Defender Technical Discussions 9 March 25th, 2004 02:05 PM
Winch Bumper Question mgrgpg Defender Technical Discussions 17 February 21st, 2004 10:48 PM
Winch wiring question flippedrover Defender Technical Discussions 4 January 11th, 2004 09:20 PM
