Winch Questions - Defender Source
Old November 13th, 2008, 01:47 PM
floyd650's Avatar
floyd650
Alex Lapidus
1994 D90 ST #1716
Winch Questions
I have a Superwinch X9 on my 90. I decided to replace my fairlead as part of my restoration and found a new one through someone on the board. The new fairlead is slightly different from my current. The opening between the rollers is about 1 inch narrower, and there are two bolt holes instead of four. So I called Superwinch and the person on the customer support line said that it'd be no problem and might even be better in someways that I have now forgotten. My questions are:
1. Is the customer service guy right (aka: it doesn't matter that the opening is smaller than the current fairlead)?
2. Do I drill new holes in the backing of the fairlead to match the pattern on my Rockware bumper or do I drill my bumper and use the hole pattern on the fairlead?
3. Does anyone have a new-condition roller fairlead for the X9 that they want to sell (in which case the previous two questions are more for entertainment purposes)?
Alex
Some pictures:
ID:	16359   Click image for larger version
ID:	16362   Click image for larger version
Old November 13th, 2008, 03:08 PM
outfield
Steve
1995 D-90 SW #351
Hi Alex,
The fairlead opening on my WARN fairlead is 7 1/4 inches wide, the width of the drum is 8 7/8 inches wide. So I would say the if your drum is 9 inches wide or less you should be fine. When spooling the wire rope to the sides of the drum it will not easily lay up against the drum flange, but that won't hurt a thing.
Old November 13th, 2008, 03:11 PM
The fairlead you got new is a Warn fairlead. Should not matter what you drill.
Old November 13th, 2008, 05:29 PM
Troys
Troy Smith
1995 D90 SW
Alex
Looks like your current fairlead is for a Superwinch Husky. Your new roller fairlead is for a Warn. Should not make much difference at all. I may have a new Superwinch roller failread, I will check this evening.
Troy
tsmith@smithpackett.com
Old November 13th, 2008, 08:18 PM
Drill the fairlead. You won't have to paint the bumper and will probably preserve it's value more (the bumper).
Old November 13th, 2008, 08:38 PM
Cred's Avatar
Cred
Clarence
1994 D90 #1057
I am pretty sure it was a Sluperwinch fairlead that I sold you. I have never owned a Warn only a Superwinch (never used the roller fairlead).
If it won't work for you, I will send your $ back and even send you a UPS return slip if you don't want it.
PM me if you want to send it back.
If it was my f**k up, my bad. I will make it right.
Old November 14th, 2008, 01:57 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Go with option 3, sell the roller, get an AL hawse and synthetic line. I fought the change for a long time, but I swear I dropped 20 lb doing the swap and rope is just so much nicer to deal with.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old November 14th, 2008, 08:01 AM
Not trying to disagree with Buck, but I saw Bill Burk at the MAR and he is an advocate of the roller fairlead even for synthetic. He says there is still sufficient friction with the aluminum fairlead to damage the line over time (and overheat it in extreme use). The downside is at extreme angles you can pinch the line, but he says it has only happened a handful of times in many years to him, and there are easy ways to avoid it if you are aware.
In full disclosure I don't have a winch, and the majority of my winch experience in on the winch b*tch end of the wire...
Old November 14th, 2008, 09:24 AM
Classic !
Old November 14th, 2008, 09:39 AM
"downside is at extreme angles you can pinch the line, but he says it has only happened a handful of times in many years to him."
I have seen it happen and a handful of times is too many.
Old November 14th, 2008, 09:52 AM
Personally I'll probably go with a hawse and synthetic myself, but I do respect his opinion very much. And to be fair, he sees more winch action in a month than most do in a lifetime. I guess his point is that if you are aware of the risks you can prevent them, and in the end the net result is better with roller + skilled & alert operater. Hawse is probably better for the part time hack
Old November 14th, 2008, 09:59 AM
"the part time hack"
Good description of me.
Ron
Old November 14th, 2008, 10:46 AM
floyd650's Avatar
floyd650
Alex Lapidus
1994 D90 ST #1716
Hey Clarence,
I got your message and PM and I don't think you F'd up at all. And was a stand-up move to try to make it right. I think that the Superwinch EPi9.0 came with the fairlead that you sent me. I have a Warn 9000 on my Toyota pickup, and although they look similar, they are in fact different. But I think that I'll just drill some holes in the fairlead and call it good.
Thanks again for being so conscientious about it though.
-Alex
Old November 14th, 2008, 10:52 AM
Cube II's Avatar
Cube II
Michele
1997 D90
Delrin rollers?
for SW 9K
I'd like to get a set for my Husky...might have them done locally but I can't find the spare time...
Michele
D90 VNTdi
+109" IIA ex-military
Sketches and doodles:
[O]===[O]
Old November 14th, 2008, 12:32 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
You can disagree with me all you want! Most sane people do.
I however disagree with Bill. I know he is a legend to a lot of people here, but to me he seems to find comfort in old technology and stick with it.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
winch
Winch Mount bjenk Defender Technical Discussions 6 November 27th, 2005 08:00 PM
Safari Gard winch bumper and winch m016324 For Sale - Parts 3 September 20th, 2005 09:52 PM
hand winch questions chirider Defender Technical Discussions 8 November 28th, 2004 10:57 AM
WARN 8274-50 Winch, THE ULTIMATE!!! RedRhinoProducts For Sale - Parts 0 September 28th, 2004 08:18 AM
winch help???? ccrover Defender Technical Discussions 3 March 4th, 2004 07:51 PM
