Winch...panel of experts - Defender Source
Old January 29th, 2009, 12:22 PM
Overland90's Avatar
Overland90
95/D90 #169; Aston Martin
I regard all your know how on many of my decisions...
my scenario:
  • 95 d90 NAS SW
  • usually loaded down with gear...500 to 1000 #'s
  • will probably be pulling a trailer...Possible Adventure Trailers type
  • Current OEM bumber w/ brush guards (pix below)
My question:
  • Is WARN the only and best answer?
  • what weight?
  • I like the clean look of my current bumber setup...how can I preserve this with out spending an enourmous amount of cash on a new bumper/brush system
Thanks in advance!
Name:	95 D90 169_500.JPG
Old January 29th, 2009, 01:07 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
I have a POE setup that I would let go pretty inexpensively. You aren't going to get any more stock looking than either the factory winch bumper or the POE...
It looks like this installed.
Let me know if you're interested. The mount I have will fit either the warn or the superwinch x9, probably many others too. The mount was powdercoated recently and the bumper has just been painted and never installed, so looks like brand new!
Old January 29th, 2009, 01:15 PM
Overland90's Avatar
Overland90
Thanks...pm'd you
Old January 29th, 2009, 01:43 PM
Warn 8274 with the Warn D90 bumper to mount it.
Old January 29th, 2009, 02:21 PM
The answer is more based around what you are doing with the truck and why you need the winch.
Old January 29th, 2009, 02:36 PM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
x2..
There are many options out there beyond Warn (not that some Warn's aren't good options). Superwinch, Ramsey, MileMarker, etc.. Don't forget there are different types of power plants, drive systems, brakes etc as well. That's why its important to know your intended use/need if you want help deciding what's best..
~Scott T.
'95 D-90 ST - AA Yellow
Old January 29th, 2009, 02:44 PM
No one ever bought an 8274 and regretted it. The only downside is price. Can't say that about any other winch out there (even Husky's and Ramsey REs have the downside of not being that fast).
Old January 29th, 2009, 03:11 PM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
Well, I think that size/configuration can be a downside of the 8274 when it comes to mounting options, but its performance is pretty undisputed. However, if you happen to be the type (rare) that 'powers out' under load a good bit, I'd still say a worm gear winch is superior to one that uses a separate brake assembly..
~Scott T.
Old January 29th, 2009, 07:12 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
After about 34 years use of my 8274 I can't say I've ever regretted buying it, even when I burned up the motor, but there are certainly times when I felt it was scary fast. On the other hand, my RE10000 will go on seemingly all day. Or at least as long as my batteries last. My favorite winch, and the one that really will go all day, is my Koenig PTO winch.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old January 29th, 2009, 07:46 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Don't forget weight, and demensions, and blocking pretty much your entire radiator.
Not that I have anything against it. I just like smaller. I would go even smaller than I am now if I could do it again for free...
edit: If your planning on wheeling it, I wouldn't mount the winch that low. You can weld a bracket to the frame and mount the winch using your factory bumper with a little cutting of the front. Or buy the factory looking winch bumper.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old January 29th, 2009, 08:18 PM
"and the one that really will go all day, is my Koenig PTO winch."
Mine too. Real winches have driveshafts. I like the PTO driven one better than the crank driven one.
I should add that east coast aka mud/hill winching is completely different than west coast rock winching.
Old January 29th, 2009, 08:30 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
What if the engine isn't running?
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old January 29th, 2009, 08:32 PM
Then neither is your winch. Duh.
Old January 29th, 2009, 08:33 PM
I get it running.
Seriously, the I am stuck in the middle of a river and need a winch but can't get the motor to run is so unlikely to happen that it really never comes up and if it should happen to come up, I would have the truck in front or behind me winch me. It is not like you can winch a mile to the trailhead.
Old January 29th, 2009, 08:34 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Thats a deal killer for me. The most common use of my winch is to right myself from a roll. And if I am using the winch, I am completely over so the motor has to be off. I know most people have different uses for them, but its a big problem.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old January 29th, 2009, 08:56 PM
Antichrist's Avatar
Antichrist
Tom Rowe
The best of both worlds I think would be a hydraulic winch with an electrically powered hydraulic pump as backup.
But if your primary use of a winch is short limited time pulls, an electric is fine.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old January 29th, 2009, 08:57 PM
How does a truck with a fried ECU run a PTO? Husky 10 would be hard to beat, and the mantec setup from RN is pretty sharp. I think Jtisdale had this setup for sale back some time ago. The primary reason I want a winch is so I dont have to walk my ass out of the woods to get a pull..
Old January 29th, 2009, 09:10 PM
I love my Husky 10... Worm drive will run all day with out any issues or over-heating.
Old January 29th, 2009, 10:01 PM
Not really. An 8274 will pull all day, no problem and fast. They are great.
But as stated, it takes up a lot of space.
Old January 30th, 2009, 08:45 AM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
I get it running.
Anyone else wanna see this happen?
Jimmy Buffett
winch
used winch now engine runs weird cpk Defender Technical Discussions 6 March 5th, 2006 04:03 AM
Safari Gard winch bumper and winch m016324 For Sale - Parts 3 September 20th, 2005 09:52 PM
Instrument Panel wiring loykd Defender Technical Discussions 6 October 18th, 2004 10:16 AM
WARN 8274-50 Winch, THE ULTIMATE!!! RedRhinoProducts For Sale - Parts 0 September 28th, 2004 08:18 AM
winch help???? ccrover Defender Technical Discussions 3 March 4th, 2004 07:51 PM
