Winch Cable - Defender Source
Old April 5th, 2011, 01:22 PM
dsh12
Daniel Hayes
1994 Defender 90 Soft Top
Winch Cable
I've found 125' 5/16" winch cable (Warn XD9000i) from $48 to $173. Is there any quality difference or would I be paying for the name?
http://www.warn.com/truck/accessorie...ent_rope.shtml
http://www.okoffroad.com/stuff-winchcable.htm <http://www.okoffroad.com/stuff-winchcable.htm>
http://cgi.ebay.com/5-16-x-125-Winch...item2c5b8b3831
Dan
94D90 NAS 3.9 LT77 LT230T Soft Top
There are no guarantees expressed or implied of the accuracy or correctness of the contents of this message, and the Author is not liable for the taking of any action in reliance upon the contents of this message. As always, do your own research. To the extent that opinions are expressed in this message, they are not necessarily the opinions of the Author.
Old April 5th, 2011, 01:31 PM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
We have new Warn 9000 take off cables for $100.
Brand new, never used, if that helps.'
Not sure if the cheaper cables are "cheaper" or if they are cheaper only because they are not "Warn" branded.
Email:
Old April 5th, 2011, 07:16 PM
Not really your question, but a 9000 lb winch and 5/16" cable is a recipe for a snapping cable.
Old April 5th, 2011, 08:46 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Yeah, I was surprised the XD9000i comes with 5/16". My Ramsey Platinum Plus 9000 came with 3/8". I assumed that was the standard for a 9000lb winch.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old April 5th, 2011, 08:48 PM
dsh12
Daniel Hayes
Is this the consensus? So what length of, I'm assuming, 3/8" will fit on the spool of an XD9000i?
Dan
Old April 5th, 2011, 11:28 PM
DMSLongLake's Avatar
DMSLongLake
Dave Sherwood
1994 D90 ST
Really?
I think Warn and Superwinch would disagree with you...
------ Follow up post added April 5th, 2011 10:43 PM ------
FYI, Amazon has the Warn part for $113.
I need a new cable as well and I am trying to decide between synth and steel...
Your winch is stock with 100' of 5/16. If you go 3/8th, you will probably need to go down to 80'.
I would stick with the 5/16 and just make sure you take good care of your cable...a well tended to 5/16 will snap less often (never) than a beat-up 3/8.
DMSLongLake
Current Rovers:
1994 D-90 ST #734
2006 LR3
2016 RRS
Past Rovers:
1997 Disco I
1999 Disco II
1995 D-90 ST #2731
2003 Range Rover HSE
2008 RRS
2013 RRS
Old April 6th, 2011, 01:40 AM
TS888's Avatar
TS888
Tony Sims
1984 110
Neither here nor there, but after having a winch with synthetic, I'd never use steel cable again.
Tony
1984 110 "Smokey" (sold)
Old April 6th, 2011, 02:07 AM
Originally Posted by DMSLongLake View Post
Really?
Actually, It really amazes me how they get away with it. If I specified something like that in my job, I would lose my engineering license and probably end up in jail.
New 5/16" cable has a strength of 9800 lbs under perfect, single pull conditions in a lab with no de-ration at at. A few hard pulls and the strength drops to less than 9000 lbs.
My personal recommendation is to have safety factor of at least 2 on a winch rope and 4 for all attachments and rigging. It is important to have the line as the weak link as attachment or rigging failure is more dangerous. Your safety is not worth half measures, IMO.
Anyway, I would suggest 3/8" synthetic. It is just so much better to work with. Take care of it and you will get years of use. Once it wears, replace it and you will be snap free....
The xd9000i should take 100' of 3/8"
Old April 6th, 2011, 02:45 PM
DMSLongLake
Dave Sherwood
1994 D90 ST
So back on topic:
5/16 x 100'
http://www.amsteelblue.com/item.cfm?itemid=44771
anyone deal with this site?
Seems like the same line as Viking (Dyneema SK75) but $90 cheaper...
And for Red90, it is 12,300#
DMSLongLake
Current Rovers:
1994 D-90 ST #734
2006 LR3
2016 RRS
Past Rovers:
1997 Disco I
1999 Disco II
1995 D-90 ST #2731
2008 RRS
2013 RRS
Old April 6th, 2011, 03:45 PM
So back on topic:
5/16 x 100'
Check with Alex, aka "Master-Pull" over on ExPo, as he usually runs a vendor discount on that type of stuff.
http://www.expeditionportal.com/forum/member.php?u=7936
10% Discount:
http://www.expeditionportal.com/foru...ad.php?t=32586
Amsteel:
http://www.expeditionportal.com/foru...ad.php?t=33515
Old April 6th, 2011, 04:18 PM
CDeWan
Clay DeWan
5.3L beastie
I am with Tony on the synthetic. I am in the market for some 3/8 synthetic that way I can get rid of the stupid roller lead. I hate the wat the cable looks.
Anyone have some 3/8 synthetic 100 feet that they want to part with
Old April 6th, 2011, 05:34 PM
bjf's Avatar
bjf
barry f
94 ST #395
Anyone see Superman IV the quest for peace? I bet Superman's hair would make a good winch line.
Old April 6th, 2011, 05:58 PM
CDeWan
Clay DeWan
5.3L beastie
I have seen Superfly and I don't think his hair would be worth anything other than a sponge.
Old April 6th, 2011, 06:14 PM
bjf's Avatar
bjf
barry f
94 ST #395
John Cryer's finest work
Old April 6th, 2011, 06:29 PM
Yes, and as I suggested, you should be looking for something with a new tensile strength over 18000 lbs. Firstly, every time a force is appliedthe life and strength of the rope is reduced. Samson has a nice graph somewhere of number of pulls to failure verus force until failure. Add this to the normal wear and tear and the chances of a failure with 5/16" gets pretty high. Simply going to 3/8" makes a huge reduction is the possibility ofa breakage.
Old April 6th, 2011, 06:32 PM
I have had the 3/8 amsteel blue on my warn for about a decade. Its now a faded grey color. I haven't been nice to it and its outlasted the original winch motor. I bought a safety thimble and spliced that in three years ago. That line has pulled many on this site out, and even me once or twice....
Old April 6th, 2011, 07:51 PM
dsh12
Daniel Hayes
All the info has been helpful! Given the option, Id choose the 100 3/8 Amsteel Blue -- Master Pull Superline XD is the ticket if you have the $$ -- as it is very close to 2x the strength of 5/16 cable and the consensuses seems to be that synthetic is easier to handle, plenty durable and safer (handling frayed cable is painful ) - the removal of the roller is one less thing that requires maintenance.
Dan
Old April 6th, 2011, 08:43 PM
What Masterpull is doing is taking regular UHMWPE rope and hot stretching it so that the diameter reduces while maintaining the strength of the original rope. So their 5/16" rope was originally 3/8" rope and that is why the strength of Amsteel 3/8" matches the Masterpull 5/16". It does make it stiffer though. It would be interesting to see if what they are doing to the rope affect fatigue strength.
winch
used winch now engine runs weird cpk Defender Technical Discussions 6 March 5th, 2006 04:03 AM
Safari Gard winch bumper and winch m016324 For Sale - Parts 3 September 20th, 2005 09:52 PM
winch cable jimmy salmon For Sale - Parts 3 July 24th, 2005 09:35 PM
winch cable jimmy salmon For Sale - Parts 0 June 3rd, 2005 07:20 AM
WARN 8274-50 Winch, THE ULTIMATE!!! RedRhinoProducts For Sale - Parts 0 September 28th, 2004 08:18 AM
