Winch bumper build - Defender Source
Old April 29th, 2015, 09:32 PM
PabloCocito's Avatar
PabloCocito
Pablo Cocito
1987 Defender Tithonus
Winch bumper build
So I started making a bumper to mount my winch, I attached the winch to the bumper mount points via a plate that is 1/4" steel. What other points do I need to attach the bumper/winch plate to?
this is what I got so far, now i just have to weld some plates to give it a finished look.
Thanks!
Old April 29th, 2015, 09:58 PM
rankar's Avatar
rankar
97 SW #2236 (Maggie)
Do you have a closeup of the mounting? My concern is possibly twisting under heavy load.
You would normally have a mount that secures both to the top and bottom of the front end of the chassis, so when the mounting bolts go through, it pinches the chassis for rigidity. Then a mounting plate houses the winch with separate mounting bolts. I'm not sure if that's happening here.
Old April 29th, 2015, 10:21 PM
PabloCocito
Pablo Cocito
Yeah that's what i was thinking too.. I'll have to make some brackets that fold down to the bottom holes. It's only attached by the top 4 for now.
Old May 3rd, 2015, 08:50 PM
PabloCocito
Pablo Cocito
Added some braces, now it should be pretty sturdy, any other concerns about the way I'm making this??
Thanks!
Old May 6th, 2015, 02:19 AM
Originally Posted by PabloCocito View Post
Added some braces, now it should be pretty sturdy, any other concerns about the way I'm making this?? Thanks!
Looks pretty good to me. No obvious issues that I can see. as with most construction, the weld and HAZ are usually the weakest points.
The real test is a destructive evaluation...winch something!
bumper, winch
Camel Trophy Brush Bar Winch Bumper and Husky Winch jjstahl3 For Sale - Parts 19 June 23rd, 2013 12:01 PM
Winch bumper build, no winch Jpayne Misc. Chit-Chat 13 October 4th, 2011 10:17 PM
LR OEM Genuine Winch Bumper and LR Winch cover rss Wanted 3 September 22nd, 2010 08:59 PM
Winch bumper build Q ? Retrofit Defender Technical Discussions 11 January 21st, 2009 09:24 AM
Safari Gard winch bumper and winch m016324 For Sale - Parts 3 September 20th, 2005 09:52 PM
