Winch/bumper advice - Defender Source
Old June 29th, 2011, 08:56 PM
HMB_Defender
Kevin Judice
'95 D90 SW Coniston Green
Winch/bumper advice
I just bought a '95 Coniston Green D90 and would like to fit it with a good brush guard and winch. I'm guessing folks on the forum have some strong opinions on this topic and I would like to hear them...as best I can tell from reading older threads on the topic, there are the ARB guys and the RockWare guys, depending on your feelings about approach angles etc. Then there are the various sub-plots re winches, although unless I get strong advice to the contrary I'm inclined to go with a Warn 9000 or similar model.
Many thanks in advance,
KJ
Old June 29th, 2011, 09:31 PM
The best bumper was the Safari Gard, the next is Rockware and past dead last is the ARB. :-) ECR is working with Safety Devices to replicate and mass produce the SG bumper, but they have not been formally released yet.
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
At this point, I think you should read a few threads about this specific subject, it will be very helpful, then ask about details. There is tons of infos on the board as this is one of the most discussed subject.
- Charles Eames
Old June 30th, 2011, 01:33 AM
I am partial to the factory winch bumper.
Old June 30th, 2011, 07:59 AM
Dredd
Harlan Boone
Ah man. Not sure on which planet Safari Gard made the best anything, but it wasn't this one. Unless you mean best looking maybe? Even then I respectfully disagree. Their design wasn't boxed so it was much weaker than Rockware's and ARB.
As to the original question. It depends on how you intend to use your vehicle. If you plan to drive across miles of vast outback and don't want to have to worry about disabing your vehicle when you hit a kangaroo at 50mph, go with the ARB.
If you plan to use the vehicle mostly for wheeling instead of expedition, then look at the Rockware.
Have fun,
HB
Old June 30th, 2011, 09:23 AM
DMSLongLake's Avatar
DMSLongLake
Dave Sherwood
1994 D90 ST
I really like my Terrafirma bumper:
http://www.defendersource.com/forum/...ad.php?t=30902
Wanted to go with a bumper that did not have the brush guard and could not beat the price...
DMSLongLake
Current Rovers:
1994 D-90 ST #734
2006 LR3
2016 RRS
Past Rovers:
1997 Disco I
1999 Disco II
1995 D-90 ST #2731
2003 Range Rover HSE
2008 RRS
2013 RRS
Old June 30th, 2011, 09:44 AM
many threads, almost like which mud tire is best. If you want a full set up Rockware best option. The Mantec winch bumper/CT brushbar/Husky is sweet but you could likely buy two rockwares for what that would cost. Tube bumpers dont belong on Rovers IMO... good luck finding a safarigard. One other option is Hard Labor Creek Fab, they are first rate and will build whatever you want. I wouldnt even consider an ARB.
On second thought the Rockware mounts for the Defender seem pretty cheesy but I have never heard tale of one getting tweaked. My RRC's Rockware mounts through the sides and top of the frame.
ID:	40000   Click image for larger version
Old June 30th, 2011, 09:47 AM
I can't recommend one bumper over another, but I'll give you my 2 cents.
Appearance should not trump performance. It should be strong enough not to bend or pull off when recovering the vehicle. Any recovery or jack points should be reenforced. Finish should be something field repairable so that it won't rust. Brush and "roo" bars can cause body damage if they are pushed into the wings. Anything attached to the bumper can get torn off, so choose accessories carefully and attach them so they're tucked in. To my mind, less is more, so having a Christmas tree full of off road accessories on the bumper is asking for it.
My ideal bumper is pretty much a hunk of 1/4 inch wall 4x4 steel square tube with the ends tapered and welded shut.
As to winches, I'm a hydraulic winch person, so Mile Marker, Ramsey and similar brands are my speed.
Oliver Whiting
Oliver Whiting
84 110, 94 NAS90,Bunch of EX-mods
Winch Bumper
Just had to jump in, The SafariGard front bumper is far stronger than the ARB, with better approach angle. as far as a direct fit. No, you have to cut the end of the frame rails to fit the safarigard bumper and it limits what winch you can fit.
to throw another bumper into the mix check out overlandspecialties.com
Old June 30th, 2011, 10:06 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Rockware... Buy Far.. tough as nails. Will not bend. Great approach angles and look very nice on a rover... ARB is a boat anchor for sure.. SG Bumpers were very nice but not avail so why even discuss them..
Legend in My Own Mind.
Old June 30th, 2011, 05:32 PM
kevkon's Avatar
kevkon
kevin
1994 D90 300tdi #730, SIII 88
If I didn't have a good tubular bumper already , I'd go with an Equipe and I'm not ashamed to say that part of that would be based on appearance. On the other hand, if I wanted something other than a tubular A-bar bumper I think I would go to Wolf for something custom.
Old July 1st, 2011, 05:00 PM
HMB_Defender
Kevin Judice
Thanks guys--really appreciate the feedback, especially to a new member asking a dumbass question, for the umpteenth time. Can't guarantee my questions will improve all that quickly but I'm glad to have this resource...and happy to have a D90!
I found a used Rockware, thanks to a tip from a forum member, that will do the trick.
Cheers,
KJ
Old July 1st, 2011, 05:07 PM
kevkon's Avatar
kevkon
kevin
Wish I was at Barbara's Fishtrap!
Is rt 1 open to SF yet?
Old July 1st, 2011, 05:36 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
mmmm Barbaras Fish trap.....
Kevin- If your in the East Bay some time drop me a line
Old July 1st, 2011, 05:45 PM
HMB_Defender
Kevin Judice
Route 1 is wide open, has been for some time...but even better the tunnel is almost finished, which should alleviate the problem entirely...although Murphy's law suggests some new problem will materialize, but we can always hope. Barbara's is open and doing brisk business.
Steve, will do. I'll be looking for someone to show me the ropes re wheeling sometime soon.
KJ
Old July 1st, 2011, 05:57 PM
Another D-90 member is in HMB, he has a white 97 SW, with an ARB (Boat anchor)... :-)
Old July 2nd, 2011, 10:53 AM
kiefffff's Avatar
kiefffff
Keith Rider
1994 Portofino ST: #217
Damn you guys are harsh regarding the ARB bumper. Hahaha. Its not THAT bad....
Old July 2nd, 2011, 07:30 PM
I love my rockware bumper but everything has it's limits, and they can be tweaked by say a jeep on 35's with a 35" spare tire on the back rolling backwards into you. If it hits the top of the brush bar it *will* bend back enough to give your fender a frown.
Originally Posted by pendy
I'm here for the D's
Old July 3rd, 2011, 08:03 AM
kevkon's Avatar
kevkon
kevin
I think this has been discussed elsewhere, but I wouldn't want a bumper on my truck that was built stouter than the frame it's attached to. I would rather sacrifice a bumper and some body panels than the frame.
Old July 3rd, 2011, 11:17 AM
I THINK DAve Marchand tweaked his at national rally years ago there were some photo's.
bumper, winch
louder horn advice chirider Misc. Chit-Chat 9 April 8th, 2008 04:49 PM
Advice on buying my first D90 mtbrooks Defender Technical Discussions 7 July 19th, 2005 07:48 PM
Advice Sought... cbass Misc. Chit-Chat 29 March 11th, 2005 07:56 PM
110 tried almost everything and it is still overheating.need some advice draaronr Defender Technical Discussions 21 November 17th, 2004 07:25 AM
any advice or comments ccrover Misc. Chit-Chat 6 December 7th, 2003 11:43 PM
