Winch Anchor: Help! - Defender Source
Old February 22nd, 2009, 03:12 PM
Santiago
Santiago Gigola
Winch Anchor: Help!
Hi,
Any body knows what type of winch anchor this is? Anybody has seen it before? Who builds it? How much does it cost?
I bought it with a bunch the recovery gear but I have never seen it before nor do I know how to use it.
Thanks in advance.
Cheers,
Santiago
ID:	17941   Click image for larger version
Old February 23rd, 2009, 08:02 AM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
Looks kind of like a portable target.
Jimmy Buffett
Old February 23rd, 2009, 12:37 PM
Santiago
Santiago Gigola
Jimmy,
What is a portable target?
Cheers,
Santiago
Old February 24th, 2009, 09:39 AM
flippedrover
Tyler
'94 D-90
A shooting target.
Jimmy Buffett
Old February 24th, 2009, 10:21 AM
Rod Hayward's Avatar
Rod Hayward
Rod Hayward
95 D90 Green #2288
Kind of flimsy unless your shooting a bb gun or a .22, I'd say. My steel targets are 3/8" high speed steel. Much heavier duty than this. I have no idea what you've got there, and I've stared and stared at it.
8-track, gun rack, spittoon, gimbal mounted beer buoy, blah, blah, blah, blah......
Old February 25th, 2009, 08:18 AM
flippedrover
Tyler
'94 D-90
True about the thickness. I'm curious about what it is. Diffidently not a winch anchor.
Jimmy Buffett
Old February 25th, 2009, 08:20 AM
To me it looks more like a light, portable, boat anchor, or something for staking out your dog...
Old February 27th, 2009, 10:44 PM
Santiago
Santiago Gigola
Hi guys,
I will copy the answer I got from the UK forum today:
"Hi Santiago,
I know what the ground anchor in the photos is. It is called a Terra Grip. It is not made any more, too heavy, too many moving parts and too big to carry. Never really caught on. It works by screwing it in to the ground down to the knuckle which is covered by the spring. You then fold it at the knuckle so the top half is lying flat on the ground and pointing at the stranded vehicle. The cross bar at the top, that you used to screw it in, is also lying flat on the ground so you pick it up a little and slide the plates on each end and fasten then so they are hanging down and sloped forward slightly. The winch hook is attached to the steel loop, near the top, and the idea is when you start winching the blades are pushed down into the ground giving grip together with the auger part. Like I said it never really caught on and was too expensive.
That Lan-cor looks a lot simpler. What are you guys thoughts on that one.
Hope that helps,
Milsiey"
Seems like "Terra Grip" winch anchor is what it is after all.
Still donīt know where it was made.....
Cheers
Santiago
winch
used winch now engine runs weird cpk Defender Technical Discussions 6 March 5th, 2006 04:03 AM
Safari Gard winch bumper and winch m016324 For Sale - Parts 3 September 20th, 2005 09:52 PM
D-90 Winch Bumper Capt Milks For Sale - Parts 0 August 27th, 2005 08:35 AM
WARN 8274-50 Winch, THE ULTIMATE!!! RedRhinoProducts For Sale - Parts 0 September 28th, 2004 08:18 AM
winch help???? ccrover Defender Technical Discussions 3 March 4th, 2004 07:51 PM
