Will this tap set work for the bulkhead and tire carrier? - Defender Source
Old April 22nd, 2009, 10:50 PM
http://www.sears.com/shc/s/p_10153_1...criptionAnchor
Old April 22nd, 2009, 10:55 PM
Probably only goes up to M10 or M12, can't tell, since the bastards didn't detail the contents.
Most tapping on the bulkhead should be M6 and perhaps M8. You will want some dies too to clean galv off the grounding lugs etc.
It is sears. What is the biggest bolt on the bulkhead? I can jerry rig the big ones on the tire carrier.
edit: not concerned about grounding lugs. A hacksaw should clean them up.
Old April 22nd, 2009, 11:01 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
http://www.e-taps.com/
- Charles Eames
Old April 22nd, 2009, 11:12 PM
Thanks Julien, JimC which ones do I need to order?
Ok, I also want a die for the tire carrier wheel studs.
Old April 23rd, 2009, 02:32 PM
Retrofit's Avatar
Retrofit
Pat
1984 110 CrewCab 200Tdi
Hmmm....
The usual metric die set will do the job but the only one you might need extra is the one for the seat belt bolts witch has a finer thread. And keep in mind those little set aren't top quality so work very gently. They are good to re-tap holes after galvanizing but in you intend to do allot of you can get your self complete kits including starters taps, intermediate taps, and finishing taps.
My 0.02$
Pat
Kirk Lazarus, Tropic Thunder
Old April 23rd, 2009, 02:54 PM
Yeah, the set will work for most M6 & M8 stuff - but you'll need m16 or something for the tire carrier.
carrier, tire, tire carrier
Another bulkhead rust post chuff Defender Technical Discussions 12 December 19th, 2006 12:14 PM
