Will This Get Through Customs? - Defender Source
Join the Defender Source Community Today
Old October 7th, 2016, 07:54 PM
shogunade
Pete
2011 RR HSE
Land Rover Defender 110 County Station Wagon USA Export 4x4 CSW Off Road TDi 90 | eBay
The car did 180k miles, then the engine got a little smokey (not really bad, but it was going to need doing), then a friend had a rear end shunt in his Defender which had a very low milage engine in it, so I made the most of the opportunity and bought the engine off him and put it in this Defender. It was cheaper and easier to get a very well known good engine and gearbox than it was to rebuild the old one. So, now this has a very low milage engine and box in. The engine and gearbox that has been swopped in was identical to the old one that came out. The log book has been updated accordingly.
Will customs clear it?
Old October 7th, 2016, 08:50 PM
it left the Land Rover factory with a 19J Turbodiesel engine, and that's exactly what it's still got!
If that is the case it should be fine.
Disclaimer------- I'm not an import expert, I stayed at a Holiday Inn Select last week.
Old October 7th, 2016, 08:54 PM
JohnsD90's Avatar
JohnsD90
74 SIII 88", 88 110, 91 110
I've never stayed at one, and I have imported before, does that make me one?
The general consensus of the law that states "original or identical replacement" is that if it came with a 19J and currently has a 19J than that is still eligible for import.
But there is never a guarantee.
Old October 7th, 2016, 09:22 PM
BlackField's Avatar
BlackField
Oscar
D110
That should get through easy peazy. Pretty good ad, looks well represented but lacks the money shots (doors, bulkhead and frame) but I suspect the seller will have no qualms putting them up.
Old October 7th, 2016, 09:43 PM
Hire Uncle Douglas to help you do it right.
Old October 9th, 2016, 09:28 PM
Bayonet16's Avatar
Bayonet16
1984/110
I pulled a 300 TDi out of my 84 and replaced it with an original model 12J prior to import. No issues. Now I just need to get the 300 back in... good luck. Nice truck.
Old October 10th, 2016, 01:00 AM
KGH's Avatar
KGH
Real Name
#1-'13 110SW #2-300Tdi #3-'12 LR4
Get pics of all lower door frames. They look questionable.
Entire front floor area needs to be disassembled, treated, painted, seals, and proper hardware. Including seatbox. Then you need proper matting or earmuffs.
Headliner is shot.
Get pics with flash of:
Outriggers under bulkhead
Rear crossmember
Floors and footwells from underside.
If it stays low price, then OK truck.
KGH - Defender Snob
What can get through CBP? bnoonan Defender Technical Discussions 7 April 21st, 2016 05:39 PM
US customs JFD Misc. Chit-Chat 16 October 15th, 2009 12:41 PM
Can you get a truck through customs without a registered importer? bitz Defender Technical Discussions 35 July 23rd, 2009 12:24 PM
UPS charging customs duties and brokerage charges cgalpin Misc. Chit-Chat 7 November 26th, 2008 08:09 AM
Houston Customs Broker Needed pcarey Defender Technical Discussions 3 January 12th, 2006 09:36 PM
