will not stay started - Defender Source
Old July 29th, 2013, 04:53 PM
chuck17
charles E Hudgins
1994 Defender
Defender 1994, while driving home , engine light came on. tried to restart 10 minutes later and was hard to start and when it started, I had to keep my foot on the pedal for it to remain running. I also smelled gas. Any suggestions on what this could be?
I have changed the Fuel pump 6 months ago.
Old July 29th, 2013, 04:54 PM
What code is on the display? It is in the passenger side footwell.
Old July 29th, 2013, 05:12 PM
Check your air hoses ... especially the big one
Old July 29th, 2013, 07:20 PM
chuck17
charles E Hudgins
1994 Defender
Okay, I came back after about 2 hours , it started right up and ran good.... Not sure if it got flooded, something like a module heated up. The computer is on the passenger side and i do have air condition...I have a new large hose that goes to the air filter.... use to have that issue , but fixed it.
Old July 29th, 2013, 07:46 PM
navydevildoc's Avatar
navydevildoc
Neill Thornton
did you have a code on the display?
Do the older 3.9s have the infamous stepper motor that controls the idle air?
Old July 29th, 2013, 07:48 PM
yes they do and yes they could cause this ...
Old July 30th, 2013, 12:12 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
Check your batteries. Mine use to do this until I replaced both batteries.
Jimmy Buffett
Old July 30th, 2013, 08:37 PM
chuck17
charles E Hudgins
1994 Defender
yes they have the stepper motor and I have one so Ill try to replace that.
------ Follow up post added July 30th, 2013 06:38 PM ------
Batteries ? Explain please...
------ Follow up post added July 30th, 2013 06:40 PM ------
Well I have Air condition and it looks like I have to remove the dash to be able to read the codes....
The service engine light is on all the time.. and after driving awhile , the engine light comes on....
Old August 1st, 2013, 12:20 PM
flippedrover
Tyler
'94 D-90
The batteries act as a buffer for the electrical system (sure someone will correct me). If the battery is bad you can get voltage spikes that the computer doesn't like. It's just something to look at if the usual suspects aren't the cause.
Jimmy Buffett
Old August 1st, 2013, 07:50 PM
chuck17
charles E Hudgins
1994 Defender
Well, I replaced the thermostat and added a quart of oil. I replaced the stepper motor.
Now when I come to a stop it cute off. It will start back up though.
Old August 1st, 2013, 07:53 PM
be corrected. Voltage regulation is performed in the Alternator.
Old August 1st, 2013, 07:56 PM
Replaced the thermostat? Why?
It needs a good service and base idle setting. Don't do that until you check the codes and ensure you have no air leaks or you'll create a worse problem than you have now.
Old August 1st, 2013, 08:34 PM
chuck17
charles E Hudgins
1994 Defender
Leastonce, Well i had a new one and just went ahead and replaced it...... Now I do have air conditioning so it seems a little difficult to read the codes. Do you have any suggestions that would be easier than removing alot of dash? The vehicle did tis once before but cleared itself up ..... YOu say good service... meaning plugs wires diet. cap ...etc?
Old August 2nd, 2013, 12:16 PM
flippedrover
Tyler
'94 D-90
The display module as well as the computer are behind a trim piece on the passenger footwell.
Jimmy Buffett
Old August 2nd, 2013, 12:39 PM
It's about time you removed the trim or you can keep guessing and wasting money forever.
Old August 3rd, 2013, 03:57 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
Based on the symptoms I'm pretty sure the engine cuts off because it overheated and the journal at the end of the connecting rod (of at least one of the cylinders/pistons) dried up and lack of lubrication bent a rod. At this point with an engine on its way out (I mean... We all know the Rover V8 engine is the weak point on those trucks) you should look into a replacement. Might as well go with the 300Tdi or 2.8. A newer alternative will be the TdV6 engine which works wonder. Anyway... Start saving money (and time).
Alternatively, you could sell your truck now and cut your losses. I'm around the corner and can help you come up with a price tag.
MonLand
1995 D90 NAS
1996 Discovery NAS
Old August 3rd, 2013, 04:15 PM
Not sure how you could come to this diagnosis unless you have more data than provided in the thread.
Old August 3rd, 2013, 11:23 PM
chuck17
charles E Hudgins
1994 Defender
Well The service light stays on , but the engine light went off. It does cut off after about 20 minutes of driving. I hope the engines okay. Not Sure if MonLand was referring to my vehicle as possibly needing a new engine.
Old August 4th, 2013, 12:28 AM
navydevildoc
Neill Thornton
Can you PLEASE for the love of all that is Rover Holy look at the code display? There are lots of guys here that will bend over backwards to help you out, but you seem to be ignoring all of the advice and doing your own thing.
When you say "It does cut off after about 20 minutes of driving" are you referring to the engine dying on you, or the service light turns off, or what?
Your engine is most likely 95% OK... it's going to be something simple that needs fixing.
Old August 4th, 2013, 11:08 AM
chuck17
charles E Hudgins
1994 Defender
I have not been to alarmed by the service engine light staying on cause had that occur before and went off. I first became alarmed when the engine check light came on while driving on the interstate. It has remained off ever sense. I do think its something simple and trying to figure out without getting into dismantling the dash and working through the air conditioner.
I am not ignoring the advice from fellow rover owners. It seems to be a intermittent issue.
When I refer to the vehicle cutting off, I mean it cuts off when coming to a stop an when I slow down to make a turn. This only occurs after a period of driving. The service light stays on always when engine started. seems to be when engine starts heating up. I appreciate your imput....sorry if I have aggravated you fellow Rover Owners.
start
Iron goat door trim & door stay CDNRover Defender Technical Discussions 0 December 6th, 2012 03:37 PM
Engine will not stay running waveridin1959 Defender Technical Discussions 30 August 1st, 2005 10:09 AM
Inspirational Speech... norros Misc. Chit-Chat 4 June 16th, 2005 12:51 PM
Still can't get my Defender started and getting desperate tmore Defender Technical Discussions 0 May 29th, 2005 11:56 PM
