Will not get into reverse gear - Defender Source
Old August 19th, 2013, 09:59 AM
Landyman1's Avatar
Landyman1
Landyman
1983 land rover 110 county
For some reason my 110 will not get into its reverse gear. It sometimes didn't get into gear but now it will not at all. Please help!
Old August 19th, 2013, 10:03 AM
Have you done any diagnostics ?
Take the cover off and look at the selector linkage ... it may be loose or require some adjustment.
The fact that it goes into reverse sometimes leads me to suspect the problem is not the gearbox but the selector.
Old August 19th, 2013, 11:11 AM
Landyman1's Avatar
Landyman1
Landyman
When I put it in reverse the reverse light comes on but the vehicle won't move and it feels like it is in neutral.
Reverse gear grinding noise. TD5 JackDEF90 Defender Technical Discussions 3 October 22nd, 2012 03:49 PM
5th gear and Reverse sticking anthony Defender Technical Discussions 2 May 22nd, 2007 12:09 AM
ZF-4HP22 reverse slipping? kiphartzell Defender Technical Discussions 0 March 20th, 2006 09:30 PM
LT230 Input gear again! Mike Hippert Defender Technical Discussions 17 June 19th, 2005 06:45 PM
reverse gear... Gkase Defender Technical Discussions 1 September 29th, 2004 06:13 PM
