Will my steering box hold together? - Defender Source
Old May 20th, 2013, 11:08 AM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
So i'm in Moab right now and i've done a few trails and now I've noticed a creak in the steering box. It turns fine, doesn't whine, has fluid and is 100% fine other than an audible creak when I change direction. It only makes the noise when I go from a left rotation to a right rotation.
I can deal with it if I loose power steering but what i'm concerned with is loosing steering all together. I'm not familiar with the internals of a steering box but what could be causing it and should i be worried about loosing my ability to steer?
Old May 20th, 2013, 08:57 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
You don't have to worry about loosing steering all together. You will just get a nice for arm work out!
Old May 21st, 2013, 02:52 AM
El Solis's Avatar
El Solis
Chris Solis
Camel Trophy 110 sorta :)
Might just be loose belt or dust on the belt. That was an issue for me in Death Valley.
Old May 21st, 2013, 07:08 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
I would also check the mounting bolts as they come loose sometimes. I have had to tighten mine on the trail truck before. Seems common.
Old May 21st, 2013, 06:53 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
Ok thanks. It's not the belts, since the noise is there when the truck is off and I jiggle the wheel back and forth. It's not leaking anything either so i'm not sure what's up. Longest loosing steering all together isn't an imminent threat somewhere on the trail, I"m happy. I'll check the mounting bolts.
Old May 24th, 2013, 06:39 PM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
Most likely in one of the TREs or the top ball joint on the arm. You could inject some grease and see if it goes away.
Steering box adjustment, backlash, drag link ?s... wicks Defender Technical Discussions 27 May 28th, 2014 02:05 AM
More Steering Box Questions kzack Defender Technical Discussions 6 May 5th, 2011 12:51 PM
Where to buy reman steering gear box? Chris Cox Defender Technical Discussions 4 February 25th, 2011 12:02 PM
Leaky Steering Box RyanS Defender Technical Discussions 19 April 11th, 2009 10:48 PM
