Will mud cause the serpentine belt to squeak? - Defender Source
Old February 21st, 2015, 01:17 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
My serpentine belt and/or bearings have started to squeal. I have had a fair amount of mud spray up on the engine lately. Could it be that the mud/grit is causing the belt or bearings to squeal? Do any of you hose of the engine (not power wash)? Is it ok to rinse the alternator off? I'm trying to determine if it's the mud causing the noise or if one of the bearings are going on the water pump or alternator.
Old February 21st, 2015, 02:13 PM
Wet mud maybe a little. Dry mud prob not. Get coolant on your serpentine and that yotch will yap like a pack of damn beagles.
Hose it down with low pressure and your fine
Theres good videos on youtube for figuring out cause. If you spray water on belt and noise stops then not a bearing.
Mark Kellgren
KM4BOR
Old February 21st, 2015, 11:23 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Thanks!
Old February 22nd, 2015, 07:38 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
The tensioners go all at once and then your DOA. If you hear noise replace it. Sucks to be far away and this puppy explode on the road. I know.
Old February 22nd, 2015, 12:25 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
The tensioner and water pumps are new-ish. The alternator is not but I have a new one waiting to be installed. I'm really hoping it is the the bearing in the alternator.
Old February 22nd, 2015, 12:40 PM
Seriously doubt it's any bearing. did you give the belt a squirt of water yet? Most common cause of belt squeals are belt contamination or pulley misalignment.
Mark Kellgren
KM4BOR
Old February 22nd, 2015, 12:47 PM
Tiktaalik's Avatar
Tiktaalik
Carl Jonsson
1995 NAS Defender 90
I've sprayed it generously with belt dressing a few times and it seems to go away for a little while. I'll try water later today.
Tiktaalik™
Old February 23rd, 2015, 05:39 AM
could also be the belt itself getting old/stretched?
Old February 23rd, 2015, 08:32 AM
LR Max
Thomason, Max
1973 Series 3 109
I get the same problem with my V-belt on my 109. Get a bit of mud on it and the entire thing starts squeeking.
2 hours on the highway solves that problem. Or pull it and clean everything. That is actually probably not a bad idea. Get a fan clutch tool, pull the fan, pull the belt, and inspect everything and clean.
Old February 23rd, 2015, 09:09 AM
From everything I've researched, you should NEVER use belt dressing on a serpentine! Many experts say it shouldn't even be sold. All it does is disguise a problem, but it's like adding glue to your dressing, making all kinds of abrasions stick to the belt causing premature wear.
Squealing is usually contamination. hose the belt off. if that doesn't work, then take it off and clean it/soak it and resintall. if that doesn't' work then replace it.
when I am working on my engine now, i take excessive care to make sure oil/coolant does not get on the belt at all, because squealing sux.
Mark Kellgren
KM4BOR
Old February 23rd, 2015, 11:09 AM
rankar's Avatar
rankar
97 SW #2236 (Maggie)
if the squealing changes while you move the steering wheel, then don't overlook the power steering pump. because when the pump starts going out, then that'll squeal like a pack of rabid beagles.
Old February 23rd, 2015, 01:41 PM
ezzzzzzz
Mark Garrenton
^ yep
Old February 23rd, 2015, 01:59 PM
Originally Posted by ezzzzzzz View Post
^ yep
OMG I can hear that just like it was yesterday....oh wait, it was yesterday
Mark Kellgren
KM4BOR
Old February 23rd, 2015, 02:08 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Ouch. Ok. I won't use that again.
Spraying it with the garden hose made it quiet.
Originally Posted by Overlander View Post
From everything I've researched, you should NEVER use belt dressing on a serpentine! Many experts say it shouldn't even be sold. All it does is disguise a problem, but it's like adding glue to your dressing, making all kinds of abrasions stick to the belt causing premature wear. Squealing is usually contamination. hose the belt off. if that doesn't work, then take it off and clean it/soak it and resintall. if that doesn't' work then replace it. when I am working on my engine now, i take excessive care to make sure oil/coolant does not get on the belt at all, because squealing sux.
Old February 23rd, 2015, 02:09 PM
So many potential causes. I'll throw in weak tensioner as another one.
Old February 23rd, 2015, 02:10 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I doubt it. Isn't that what the tensioner is for? To keep tension? In the past I have flipped the belt the other direction. Is that a no no?
Old February 23rd, 2015, 02:11 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
New tensioner assembly and water pump was installed 3 years ago.
Old February 23rd, 2015, 02:44 PM
reversing the direction of the serpentine often solves the problem when the problem is the belt
Mark Kellgren
KM4BOR
Old February 23rd, 2015, 03:03 PM
Tensioners do get weak, but three years is plenty young enough.
Old February 23rd, 2015, 03:56 PM
rankar's Avatar
rankar
just in case you forgot
200tdi serpentine belt replacement DieselDef Defender Technical Discussions 6 September 23rd, 2010 02:40 PM
'97 Defender 90 Serpentine belt crown14 For Sale - Parts 0 February 5th, 2010 04:01 PM
serpentine belt new in plastic 4.0 mountainviewrover For Sale - Parts 3 May 8th, 2007 08:41 AM
300 Tdi Serpentine belt failure roverboy Defender Technical Discussions 5 May 25th, 2006 02:53 PM
Bando D90 97 Serpentine Belt wea For Sale - Parts 7 December 24th, 2005 04:08 PM
