Will mud cause the serpentine belt to squeak? - Page 2 - Defender Source
Old February 23rd, 2015, 04:04 PM
I have had brand new belts squeak after a month or so. Try Marks suggestion of flipping it over, cant hurt. A trick I have used is to take a beeswax candle and smear it on the belt on both sides. If the noise subsides or goes away you know you have a glazed belt.
Old February 23rd, 2015, 04:29 PM
You can also use a bar of soap.
Mark Kellgren
KM4BOR
Old February 23rd, 2015, 11:04 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I also have been suggested to use a different belt. Apparently the Goodyear Gatorback 4070630 (7PK1600) works wonders compared to stock. The cogs are offset and the whole design is supposed to be much more quiet.
Old February 23rd, 2015, 11:43 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
They are - running them on my trucks as well...
Old February 24th, 2015, 01:24 AM
one acts as a belt dressing, ie makes its sticky so it doesn't slip, the other acts as a lube
Old February 24th, 2015, 04:04 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I'm suspecting it's the belt not the bearings. A few drops from the hose makes it go away almost instantly then it comes back after a while of driving (once dry). I'm ordering some Gatorbacks belts.
Old February 27th, 2015, 01:43 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I flipped the belt and the loud squeal is gone but its still making a more tolerable noise. I inspected the belt and I noticed that these things dry up a bit long before they are worn out. The oil in the rubber is gone on the ribs. The ribs are very dry which would cause them to be less flexible make noise. Now I have two used belts as back ups and two Gatorbacks scheduled to arrive Monday. For anyone about to install a new one, do yourself a favor and don't get the Stock OEM belt. It's more expensive and will end up making a terrible noise before it has reached its end of life.
Old February 27th, 2015, 02:11 PM
please post results of the gatorbacks. I still have a little noise too. And don't get your belts from autozone either.
Mark Kellgren
KM4BOR
Old February 27th, 2015, 02:13 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Will do. They arrive Monday.
Brian, how long have you been using yours?
Old March 3rd, 2015, 01:59 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I got the belt. It says Allmakes 4X4 on it.
ID:	115126   Click image for larger version
Old March 3rd, 2015, 02:11 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Turns out Amazon sent me a used belt of the wrong make. Thanks Amazon. According to Brian it is supposed to look like this.
Old March 3rd, 2015, 02:13 PM
A USED belt? WTF?
Mark Kellgren
KM4BOR
Old March 3rd, 2015, 02:15 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
The same one they sent Brian last year.
Old March 3rd, 2015, 02:18 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Why, God, WHYYYY?
#whitepeopleproblems
Old March 3rd, 2015, 02:21 PM
Why, God, WHYYYY?
If it's for only a moment, you can actually relate to my perplexing beagle problems.
Mark Kellgren
KM4BOR
Old April 21st, 2015, 11:02 PM
jyoungjr01's Avatar
jyoungjr01
95 D90
When I start up my 1995 D90 is squeals for about 5 to 10 seconds then runs fine and it quiet. Any thoughts on what the problem could be, how I can fix it?
Old April 21st, 2015, 11:09 PM
bjf's Avatar
bjf
barry f
94 ST #395
Could be water pump shitting the bed.
Old April 22nd, 2015, 06:21 AM
Originally Posted by Rocky View Post
Tensioners do get weak, but three years is plenty young enough.
Shouldn't be an issue on a V belt truck since they aren't spring loaded like the one on a serpentine belt truck.
Old April 22nd, 2015, 08:16 AM
jyoungjr01's Avatar
jyoungjr01
95 D90
Thanks BJF. I am a new owner and am just getting into all this nonsense for the machine that I'm nuts about. I just had a new water pump put in. Could it be a bad belt? Anyone think its a major issue? It runs seemingly fine I just hate that sound when it cranks. Just fielding ideas for how to correctly fix the noise.
Old April 22nd, 2015, 09:17 AM
Most likely one of the belts is set slightly too loose and grips when the friction warms it up a little. It's a straight forward job to tighten the belts ... The alternator belt being easiest. Check which belt it is by spraying a little water on it ( do them one at a time obviously ) and then tension it to specification ...
If they are all to specification it could suggest a component on the way out.
Don't what ever you do over tighten the belts as the will lead to premature failure of components.
200tdi serpentine belt replacement DieselDef Defender Technical Discussions 6 September 23rd, 2010 02:40 PM
'97 Defender 90 Serpentine belt crown14 For Sale - Parts 0 February 5th, 2010 04:01 PM
serpentine belt new in plastic 4.0 mountainviewrover For Sale - Parts 3 May 8th, 2007 08:41 AM
300 Tdi Serpentine belt failure roverboy Defender Technical Discussions 5 May 25th, 2006 02:53 PM
Bando D90 97 Serpentine Belt wea For Sale - Parts 7 December 24th, 2005 04:08 PM
