Will Calipers and rotors from a 10 spline D90 work on a Disco Axle - Defender Source
Old December 13th, 2010, 08:01 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
I have a Disco axle to put in the front of my 90, can I just pull the rotors and calipers off the 10 spline d90 axle and use them on a 1997 Disco axle?
I started thinking about this after I had already pressed the races into the disco hub assembly.
So I want to bolt the older style rotors to the Disco hub assembly and use the old style calipers.
Thoughts?
Old December 13th, 2010, 10:29 PM
huck1974's Avatar
huck1974
shane cates
94 d90
Thoughts?
It may be a difference in years or something, but I am confused by your question. My Defender has CV style half shafts. I have no idea what parts you are trying to change and what you consider axles. A lot of old disco parts are real close to my shop. I could check something for you.
And hay
And I love you too
Old December 13th, 2010, 11:05 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Sorry, I mean the whole deal.
The entire disco axle housing, internals, hubs, everything. The question was whether the 10 spline 90 rotors and calipers can be bolted up to the disco hub assembly?
Old December 14th, 2010, 02:54 AM
Thoughts?
Of course. Simple remove the hubs on both, unbolt the rotor and bolt it onto the Disco 24 spline hub. Re-install hub to disco axle. Now bolt caliper on and you are done.
Old December 14th, 2010, 03:06 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Yup, they will fit.
Old December 14th, 2010, 05:50 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
Thanks, thats what I though, but got nervous once I went ahead and banged in the races.
Old December 14th, 2010, 06:01 AM
The Dro
Dro
1988 Ninety
Yes you can... My RRC had Disco I rear axle. The D90 is no different.
Old December 14th, 2010, 11:32 AM
yes. though you could also use the rotors and calipers from the disco if they are any good. in fact, they should be identical.
when I converted my 90 front axle to 24 spline I used all D1 parts. My 90 calipers were partially siezed so I used the d1 calipers. side by side could not see any difference.
Thoughts?
Old December 14th, 2010, 12:08 PM
good thing to look after but I thought the metric shift was in the early 80's. Stage One and late SIII are part or all metric and my 84 d90 is all metric.
The only potential 'issue' that i can think of is that the mounting hardware on the early stuff is standard and in the early 1990's it switched to metric. I have known of having to slightly drill out the mounting tabs on the earlier callipers to use the metric hardware.
-Jeff
Old December 14th, 2010, 02:50 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
what does NF stand for?
Old December 14th, 2010, 03:34 PM
110 calipers are bigger. Tom assuming you already knew that you have to retain the plumbing up to the caliper if you are using the 110 calipers. Sent you a pm have a shipment on its way with items for you included.
Old December 14th, 2010, 03:57 PM
Oh yeah.
Doh!
edit...this is for his 90...
Originally Posted by 130Tdi View Post
110 calipers are bigger. .
Old December 14th, 2010, 10:36 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Yes, this is for the 90.
What do I do with the ABS wires on the front disco axle when I put it under the 90?
Old December 14th, 2010, 11:16 PM
I cut them off as close as posible to the top of the sensor and then have to dril a hole in the flexline to rigid line bracket to fit over
90, axle, d90, disco
Axle swap 90 and 110 101 tomaco1 Defender Technical Discussions 6 November 22nd, 2010 08:27 PM
Disco axles on a 110 tomaco1 Defender Technical Discussions 2 October 22nd, 2010 11:22 PM
Axle Swap w/Disco I founD90 Defender Technical Discussions 24 June 17th, 2010 11:30 AM
Rovertracks new Rover9 superaxle :) Buckon37s Misc. Chit-Chat 8 December 18th, 2008 12:53 PM
Rovertym slider step / free 10 spline spares Abrooks For Sale - Parts 1 November 17th, 2005 08:42 AM
