Will a 300tdi run on kerocene? - Defender Source
Old April 28th, 2011, 08:48 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Just curious.
Legend in My Own Mind.
Old April 28th, 2011, 09:19 AM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
till the pump blows.
http://forums.lr4x4.com/index.php?sh...1&#entry506391
http://forums.lr4x4.com/index.php?sh...=1&#entry80125
I know a lot of guys that run Farm Diesel to save a few bucks. Most officers will not check that when you get pulled over (somebody has to rat you out basically)...
Old April 28th, 2011, 09:51 AM
I have used it when running low and pull into a station that doesn't sell diesel but does sell kerosene. OK for spot/sporadic use but not good for a full tank etc. This is escpecially true for the "clear" kerosene sold for heater use.
Old April 28th, 2011, 11:25 AM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
Up here we buy 50/50 all winter. 50% kero 50% diesel. It is only good in very cold weather and pings like crazy if we get an odd warm snap.
Eric Riston
1-800-533-2210 ext 231
Direct Line 518-539-2231
Old April 28th, 2011, 12:24 PM
TS888's Avatar
TS888
Tony Sims
1984 110
It will if it's mixed 20/80 with used motor oil. Although the people here that run UMO usually just cut it with petrol as that's easier to buy than "paraffin" (Brit speak for kerosene).
Tony
1984 110 "Smokey" (sold)
Old April 28th, 2011, 01:07 PM
Originally Posted by TS888 View Post
....with used motor oil....
NO!!!!! Not with a "modern" diesel. The additives in the oil cannot burn and will destroy the injectors and make the rings stick.
Old April 28th, 2011, 04:44 PM
bharris's Avatar
bharris
Brad Harris
1994 d90 300tdi "Nola"
300tdi = modern
Old April 28th, 2011, 10:53 PM
Mid 90s modern, yes. Motor oil and ATF in fuel is for old style diesels.
Old April 28th, 2011, 11:24 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
I'm a bit confused as to what is ok and what isn't
If one is to run on used motor oil, what level of filtering beforehand is sufficient? I feel like engine flakes might not be the best being sprayed through tiny injectors. ATF I'm sure is fine, but a bit thick.
Kerosene seems fine if cut with diesel, I'm just not sure how to tell the different types though.
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
Old April 29th, 2011, 06:52 AM
TS888's Avatar
TS888
Tony Sims
1984 110
A number of people on the forums here in the UK run 200TDi's and 300TDi's on used oil of various origins -- motor oil, hydraulic oil, ATF, gear oil... They filter it before using, cut it a reasonable viscosity with gasoline, and swear it works fine and has no detrimental effects. And, it's generally free, which is a strong incentive in the land of $8.50 a gallon diesel.
------ Follow up post added April 29th, 2011 11:55 AM ------
Here in the UK, diesel for off-road use carries a red dye, and if you get caught running it on the road, it's big trouble. Stops for fuel checks are reasonably common, the police carry test kits and will dip the tank and deliver the verdict on the spot.
Tony
Old April 29th, 2011, 07:49 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
All good info. The reason I was asking was because I have about 5 gallons left over from the the heater. I guess I can mix it in a bit at a time every tank full then...
Old April 29th, 2011, 10:07 AM
kjva
Ken Jackson
1985 110 Wagon
If you are stopped at a checkpoint run by State Troopers in VA they will check your tank for offroad diesel. The size of your tank determines the category of the offence. Anyother common misconception is that you can run offroad diesel with "Farm Use" plates on a truck. We need to be registered as a farm to buy offroad or they will charge you full price, the Reefer drivers complain about that.
Old April 29th, 2011, 10:30 AM
tjfslaughter
thomas
Burbon
I wouldn't mess with it, besides there are not too many farm diesel places in North New Jersey. But I know a guy in Kanasa that has an AUX tank in the bed he keeps the red diesel in there, and the regular stuff in the tank if he is ever checked..... (the Red is for his "farm equipment"). The only way he will ever get busted is if they check his injectors.
Back on topic. I think a lot of Military Generators can run on Kerosene (current production ones).
Old April 29th, 2011, 02:12 PM
OK, let's reiterate....
You should not put in stuff like motor oil or ATF. Both have additives that cannot burn. These additives can and will build up inside the engine.
Kerosene can work, but need SAFE lubricity additives such as diesel fuel conditioners or biodiesel.
300tdi, tdi
Do you run your 300tdi on biodiesel? How do you like it? Manimal Misc. Chit-Chat 29 February 15th, 2014 11:37 AM
NAS D90 300tdi exhaust? Chris Cox Defender Technical Discussions 19 June 13th, 2006 04:59 PM
300Tdi wings/ radiator finisher (defender) Lyman Wanted 2 March 8th, 2006 05:51 AM
1995 Discovery 300TDI, Trail Ready.... Joe B For Sale - Vehicles 1 June 23rd, 2004 06:26 PM
