Will 3 Carling switches fit here? - Defender Source
Old July 14th, 2009, 09:59 PM
cabell's Avatar
cabell
Cabell Crowther
The piece of paper approximates the 3 gang cluster size, but I'm not sure the depth to the wiper motor is adequate. I think the switches are about 1.5" deep. Anyone had any luck putting them here?
Old July 14th, 2009, 10:41 PM
Why not use factory switches?
Old July 14th, 2009, 10:46 PM
cabell's Avatar
cabell
Cabell Crowther
I need an on off on switch for my electric fan as well as a couple other apps. Is there an on off on factory switch? BTW, this is a late td5 dash, so no factory switch opening here.
NashvilleRover's Avatar
NashvilleRover
Dendy Jarrett
2009 LR3- Well Built
Factory switches still available through Expedition Exchange.
And I am sure through AB or Rovers North.
Dendy
Old July 14th, 2009, 10:48 PM
Yup, factory switch and it looks just like the dimmer switch on NAS trucks. ECR uses them on their builds, EE sells them as I am sure our friends at AB, BP etc. can. IIRC there is one somewhere in my stack of parts for when I get around to mounting the lights I got from CvC in 2004 or so.
Ron
Old July 15th, 2009, 12:20 AM
That panel is easy to remove to check the backspacing. I'm thinking you would have no issues with Carlings. I have that part from a 90 with the cuts outs for three switches if you want to take measurements etc. Its not fun cutting one of these out for switches and doing it well. I used a dremel tool, drill, files etc
Old July 15th, 2009, 10:11 AM
cabell's Avatar
cabell
Cabell Crowther
Yes please let me try this out.
Old July 15th, 2009, 10:31 AM
I can't remember the exact name of those kind of switches, but lots of cars used them, i.e. minis and stuff. Here is a link to one intended to be a fan switch:
http://www.cbsonline.co.uk/sva-rocke...fan-3935-p.asp
Old July 15th, 2009, 10:40 AM
Haston
Christopher Petite
The three-switch gang would have fit on that panel in my 97SW, but I didn't like the prospect of having to cut the metal plate, as Doug alluded to. I ended up putting the three switches in the console, to the left of the trans shifter, where it was much easier to cut holes and just as easy to wire and tap for illuination. I bought the swtiches and the switch holders from Iron Goat, which has first-rate customer service. Best of luck. H.
Old July 15th, 2009, 10:51 AM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
May not be the cheap option, but you can remover that Td5 late part and install the wiper motor cover from a NAS 90 in that location and then that will give you the 3 factory switch type locations.
The Td5 piece has a lot of foam though before you get to metal, so unless you make a trim plate that the switches fit into you can't directly put switches into that panel as there is too much foam.
There are factory swithes for on off and 3 way, etc.
It would be cheaper to make a little alloy panel and paint it black and then attach it to that area.
In a Td5 there is nothing behind that (wiper motor is on the passenger side), so you have lots of room.
Email:
switch
Hannibal tent fit on a stock 110 rack pcarey Misc. Chit-Chat 8 February 4th, 2012 08:49 PM
Carling Switches mgrgpg Defender Technical Discussions 5 September 12th, 2007 06:06 PM
Do Jeep seats fit the D-90? arbik Defender Technical Discussions 7 January 30th, 2005 08:25 PM
arb switches - where to put scoloco Defender Technical Discussions 8 January 10th, 2005 09:25 PM
Can I fit 35's? NC4X4 Defender Technical Discussions 2 July 20th, 2004 02:44 PM
