Wicked Squeak - Defender Source
Old July 16th, 2004, 02:48 PM
ronward's Avatar
ronward
Redsrover
None - sadly
Wicked Squeak
Hi all, got a high pitched squeak from the bonnet area of the 90. Not mechanical, but related to vehicle motion as it's going down the road. I sprayed lubricant all over the latch and rubber buttons on the underside of the bonnet to no effect. Is there a grease I can use in the hinges that won't break down the rubber in there, or discolor the paint over time? The noise could be from my dash, but I don't think it is.
Any thoughts?
Old July 16th, 2004, 03:39 PM
I put anti seize in the latch part to keep it working. If you are not sure it is the bonnet then pull the bonnet off and drive around, if you don't hear the squeak with the bonnet off then it's the bonnet. You might also want to check to see if the bonnet is rubbing on the wing tops.
Clutch Squeak Bozman Defender Technical Discussions 6 August 27th, 2009 11:18 AM
Cheap 2001 F350 crew cab diesel 4x4 ECR For Sale - Vehicles 22 December 4th, 2008 04:39 PM
Rear brakes(?) squeak under load kolvedic Defender Technical Discussions 3 June 25th, 2007 03:17 PM
Shutoff Squeak Jon_Winningham Defender Technical Discussions 1 January 23rd, 2007 03:46 PM
