Why you should use synthetic oil and change frequently - Defender Source
Old August 1st, 2009, 09:21 PM
I had Frank do the head gaskets and cross seals on my 1995 RRC LWB as I just did not have time with all my other projects and I hate doing heads. This truck had regular synthetic oil changes since its second owner at about 40k and has 170k now.
Frank said there was basically no sludge in the motor and that the oil pick-up was spotless. He was truly impressed and commented several times that he had not seen one with that high of miles in that kind of shape (heads had never been off before either so it was not like it was somehow recently cleaned).
Ron
PS Yeastie was equally clean, at least from looking down the fill cap, and she had synthetic since new.
Old August 1st, 2009, 09:49 PM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
I have always used synthetic oil, I have bounced from Castro, Mobile1, amsoil since my first time use but always stuck with it.
Engine protection is when there is practically no oil left when I changed the oil once and forgot to tighten the oil filter, drove a few miles down the road with my late father and the engine light come on..afterwards the car just turned off at 25 mph, we both thought it was toast. I tighten the filter, added oil back in...waited 30 minutes for it to cool down & turned it on and it just ran like nothing happened.
gotta love it.
Old August 1st, 2009, 11:05 PM
I am guessing the 0w40? Ive ran this in Hunter the last couple changes. I think its cleaned all the stuff holding the engine together. Back to the 10w40 M1, the best for the Rover IMO. I hope to pull the top end off my D90 in the coming weeks. I am anxious to see how things look..
Old August 2nd, 2009, 10:02 AM
landrovered's Avatar
landrovered
S. Smith
72 Series III 109 Diesel
On my RRC I went with the Mobil one 10/50 on my last oil change since my engine has 212K on it, I chose the 10/50 because the bearings are getting a bit worn and the extra weight keeps it running quietly without clicking or clacking on startup.
My 110 has 118k and I run Mobile one 10/40 in it.
Old August 2nd, 2009, 10:51 AM
mikeybob2@msn.com's Avatar
mikeybob2@msn.com
Michael Sabanovich
1994 Defender 90 #1880
My 135k+ motor as never had synthetic so is it wise to switch? I'm worried of what might happen to gaskets, etc.. If I went to Mobile 1 what steps should I take to switch?
1994 D90 #1880
Old August 2nd, 2009, 12:00 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
I use that Mobil 1 10-50W in my diesel as well. If you read the literature it is ideal for the older engine designs we use and is NOT marked energy-efficient.
Switching causing leaks is an old wives tale, true at one time long ago but today they add seal conditioners to prevent issues.
Old August 2nd, 2009, 12:15 PM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
I used to back that up... However after a month or so of running 0w-40 in my classic (which had used dino previously) it developed some leaks. I switched back to Rotella t 15w-40 and the leaks disappeared.
I run 0w-40 in the 90, however and it's completely leak free.
There's some truth to both sides. Some are happy with the switch and some aren't I've concluded.
Old August 2nd, 2009, 12:19 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
I wonder if the 0 weight had as much to do with that as the synthetic? In my 140k '97 Land Cruiser I use the Mobil 1 10-40 High Mileage but then of course it's a Toyota.
Old August 2nd, 2009, 12:21 PM
cellulararrest
Chris Snyder
Whoops. I meant 10w-30 in the classic (That was before I found out it's not very good for our camshafts) and 0w-40 in the 90. So 10w-30 to 15w-40.
Maybe the slightly lighter weight did contribute? I don't know. But it's completely dry now with 15w-40 rotella.
Old August 2nd, 2009, 04:29 PM
Switch to synthetic now and change oil filter at 1000 miles. If it is heavy (you will be able to tell), keep changing the filter and topping up every 1000 miles until it is not heavy anymore.
Old August 2nd, 2009, 09:16 PM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
What the synthetic does is clean out the sludge inside your engine with every oil change, so in a higher milage engine which has only run Dino oil this will cause minor leaks since the sludge residue from Dino oil keeps the old brittle seals happy.
I run a bit thicker synthetic oil and the leak is minor...but the engine protection is worth it.
Old August 4th, 2009, 11:20 AM
Campbell's Avatar
Campbell
Rich Campbell
06 LR3 01DII D90s sold
Ron what synthetic are you using?
Rich
Ron
Old August 4th, 2009, 12:10 PM
If you do oil analysis, you will get different wear numbers with different oils. The best synthetics do give the lowest wear numbers. Change frequency does not matter much as it is fairly hard to get an oil these days that breaks down within the change interval. It is governed by oil contamination which is engine dependant and can only be determined from analysis.
Now for an old school engine like Rover V8, it may not matter a lot. the oil analysis that I've seen on Rover V8s is scary. Wear numbers were 10 times higher than a modern engine.
Old August 4th, 2009, 12:15 PM
Rich
I vary what I use depending on what I have around, but I like mobil one 0w40 and royal purple 5w40.
Old September 6th, 2009, 10:30 PM
Crower hates synthetic and swears we all need ZDDP additives in our motor oil?
Old September 7th, 2009, 01:35 AM
I would agree on ZDDP for any new cam set up. Synthetic is niether here nor there as far as ZDDP goes. Two seperate issues.
Old September 7th, 2009, 08:56 AM
Jon_Winningham's Avatar
Jon_Winningham
Sterling M Archer
1995 AA Yellow NAS D90 #2986
So would it be wise to add ZDDP to our old school Rover 3.9's oil???
Per ZDDP's website:
1995 NAS Defender 90 AA Yellow #2986: Current
2009 Range Rover Supercharged Black/Black: Current
1993 NAS Defender 110 #375/500: Sold
1995 NAS Defender 90 Soft Top Beluga Black #2556: Sold
1991 Range Rover Hunter Green: Sold
1997 NAS Defender 90 Station Wagon Portofino Red #128: Sold
1993 NAS Defender 110 Beluga Black #215/500: sold
Old September 23rd, 2010, 10:55 AM
discotdi
Todd Miller
Land Rover
so I am changing the oil in my new "old" truck. It has a 200 tdi and I assume has always been run on dino oil. I have some Mobil one 5w40 synthetic that says it is for diesel trucks that call for 15w40 dino oil.
Should I go with Synthetic? mileage of engine is unknown and it currently has some oil leaks. if I do go with Synthetic should I then change the oil and filter in about 1000 miles to catch any junk that breaks free? or should I mix with dino and synthetic and slowly break into full synthetic?
Old September 23rd, 2010, 11:09 AM
Retrofit's Avatar
Retrofit
Pat
1984 110 CrewCab 200Tdi
Been running synthetic for 2 years in my 200tdi and here with cold weather I wouldn't want I it any other way. Haven't had engine related problem since an mine is my daily driver.
I wouldn't recommend mixing oils types.
Pat
Kirk Lazarus, Tropic Thunder
Old September 23rd, 2010, 11:11 AM
Todd,
Make sure the oil is rated for diesel. Thats actually a big deal. I run the Shell Rotella T6 5-40 synthetic year round. The first oil change on one of these I always add a quart of Rislone. It totally removes all sludge but you should change the oil in about 1000 miles. I did this the first two changes in my 300 and it cleaned things up a lot. I have heard you shouldn't mix synthetic and dino due to additives in the oil breaking down quicker.
Oil Change gtg067i Defender Technical Discussions 31 July 13th, 2005 10:24 AM
Sick Of Messy Oil Change javelinadave Defender Technical Discussions 17 October 12th, 2004 09:28 PM
Oil Change Screw-up zed111 Defender Technical Discussions 9 July 19th, 2004 11:48 PM
