Why you dont leave your truck sitting for 4+ years - Defender Source
Old April 11th, 2016, 11:31 AM
wcampbel@nas.edu's Avatar
wcampbel@nas.edu
Bill Campbell
1994 D-90 ST
I feel like a neglectful parent.
Old April 11th, 2016, 11:54 AM
97-D90-736
Nick Vogel
1997 D-90 / 2012 LR4
Is that rust on the float? Hopefully the rest of the lines don't look like that. You can thank the bullshit gas we have now for some of that 'help'.
Old April 11th, 2016, 11:56 AM
I like how you put that part on the ground. I am imagining that it was placed with the fury of a thousand busted knuckles and scrapes.
I've been there
Old April 11th, 2016, 01:00 PM
wcampbel@nas.edu
Bill Campbell
1994 D-90 ST
Ya it is some kind of rust/corrosion and it definitely doesn't smell like gas anymore. I hope the rest of the lines aren't like that or I am royally screwed. Cleaned the tank out and have a new pump on order. Should be interesting to see if it cranks.
There may have been some anger involved. Also a healthy dose of guilt for ever letting it ever come to this.
Old April 11th, 2016, 01:52 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
While it looks bad(inside), I notice that your supply and return line fittings are surprisingly RUST-FREE!
Rent my
Old April 11th, 2016, 02:13 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Change your filter regardless.
Old April 11th, 2016, 02:41 PM
wcampbel@nas.edu
Bill Campbell
1994 D-90 ST
Yep already done. Good advice though, thanks.
------ Follow up post added April 11th, 2016 02:44 PM ------
Ya my truck is generally pretty good on rust except the rear crossmember and rear axle housing. It's kind of odd actually. Like all the way up to the rear crossmember itself is fine and then the crossmember itself is a mess.
Old April 11th, 2016, 03:17 PM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
I'm afraid the answer might not really matter, but was it stored indoors or out for those four years?
~Scott T.
'95 D-90 ST - AA Yellow
Old April 11th, 2016, 03:34 PM
Omero's Avatar
Omero
Omar Alomar
2000 D110 CSW 6.2 LS (was TD5)
Originally Posted by wcampbel@nas.edu View Post
Attachment 146970
Old gasoline turns to varnish (I bet it smells that too). You need to clean the fuel system and blow the line with compressed air then dissolve the old varnish with seafoam.
Old April 11th, 2016, 03:44 PM
Starting with fresh fuel lines looks easier.
Old April 11th, 2016, 03:50 PM
wcampbel@nas.edu
Bill Campbell
1994 D-90 ST
Indoors.
I believe most of the fuel had drained back into the tank, so it didn't sit in the line.
I basically took the truck down to do a lot of work on it and got side tracked. Most of the work is done and now I am getting back to the point where I can start it again I emptied the tank to get fresh gas in it and that's when I pulled the fuel pump and saw the destruction.
Old April 11th, 2016, 03:57 PM
Omero's Avatar
Omero
Omar Alomar
Depends on their condition, I had a chevy truck left for 7 years, I just put some seafoam and blew it with air and it's still running beautifully. Only changed the pump and filter, old injectors worked fine.
Old April 11th, 2016, 06:01 PM
smob's Avatar
smob
Steve
'97 Arles Blue SW #2131
Your rig isn't in Annandale, is it? There's a yellow ST that has been sitting for a long time in my ex-girlfriends neighborhood.
-Ren Ching
Old April 11th, 2016, 08:55 PM
wcampbel@nas.edu
Bill Campbell
1994 D-90 ST
Fairfax. I am 45 and still have tons of crap at my folks house.
Old April 11th, 2016, 09:19 PM
smob's Avatar
smob
Steve
Ha. Same age and same crap at parents house(s).
-Ren Ching
Old April 11th, 2016, 09:53 PM
87 D110 (Ruby)
its funny really....I don't leave my boat for longer than 4 months without putting fuel stabilizer in the gas tank. Weird really that people generally don't do that with cars.
Restarting after 3+ years of sitting wcampbel@nas.edu Defender Technical Discussions 5 May 26th, 2015 11:52 AM
Epic fail ... Dont play in the sea with your landy leastonce Misc. Chit-Chat 10 May 13th, 2013 06:48 PM
I dont know why I want this but I do phoenix37 The Flea Market 2 January 22nd, 2010 02:00 PM
Can I leave the sway bars off? 97-D90-736 Defender Technical Discussions 17 August 10th, 2009 10:21 AM
WHY WHY WHY am I blowing through suspension bushings? KevinNY Defender Technical Discussions 27 September 13th, 2007 02:29 PM
