Why would overheating occur with high electrical loads? - Defender Source
Old May 10th, 2009, 10:03 PM
johnpiero
John Brancato
none
I've had the weirdest problem happen a handful of times already but i have no clue as to why. Now this doesn't happen every single time, but each time it has happened (approx 5 times over the past 6 months) it happens the same way every time. Here how it goes: I'm driving at about 70mph with my lights and fan on and the temp gauge is right in the middle. Then as I put on my brights or honk my horn the temp gauge goes way high. The strangest thing is that the gauge goes up very fast...for example, if i put my brights on the temp gauge goes up to red in about 3 seconds. then when i turn them off, it goes back down in about 3 seconds. WHAT THE HECK COULD THIS BE?
Thanks fellas.
Old May 10th, 2009, 10:20 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Sounds like an electrical fault somewhere, not an overheating issue. Unfortunately, those types of oddball issues are never easy to track down.
-Hans
My oil line fix
My 100k stopped odometer fix
Old May 10th, 2009, 10:23 PM
bad ground causing voltage to find another path. hi beam and horn share a switch don't they?
Thanks fellas.
Old May 10th, 2009, 10:55 PM
Actually quite common when people swap out gauges, etc. I think the best solution is just a separate ground for the temp gauge, but I cant say exactly what fixed it since I did like 3 different things at once in violation of scientific method.
Old August 26th, 2009, 09:04 PM
Campbell's Avatar
Campbell
Rich Campbell
06 LR3 01DII D90s sold
John did you ever resolve this....I'm having that same problem.
electrical, overheating
Help With Electrical Gremilins mdmccallum Defender Technical Discussions 8 January 7th, 2006 01:24 AM
Timing and Overheating mkerr2112 Defender Technical Discussions 10 July 6th, 2005 09:31 AM
Electrical for beginners paulb Defender Technical Discussions 5 October 18th, 2004 01:58 PM
on-going electrical problem... vesparover Defender Technical Discussions 3 October 23rd, 2003 11:13 AM
