Why not remove the inner bushing sleeve? - Defender Source
Old June 10th, 2004, 07:00 PM
ezzzzzzz
Mark Garrenton
I may be wrong but the weak component in a link seems to be the bolts for the bushings. In a three link, the bolts in a center link bushing would be highly probable to sheer in a frontal collision or comparable impact. Most large bushings use a 9/16 bolt. Why couldn't you remove the center sleeve, drill out the bracket (made from 3/8" or 1/2" plate) and install a bolt equivalent to the sleeve OD? I'm building a SG 3-link setup but intend to use 1.75" OD 1.00" ID DOM tapped to accept 1.25"-12 B-7 allthread (for adjustment). The bushings would like those found at PolyPerformance. Once fabricated, I'd wrap the bushing sleeves with appropriate flat stock to strengthen the .120" thick bushing sleeve (in case of collision). This link should be substantial enough to allow the allthread to rotate in one sleeve eliminating excess bushing loads. I figure I must be missing something here.
Clutch Master/Slave Cylinder Hydraulic Leak Merged Threadfest Buckon37s Defender Technical Discussions 223 September 1st, 2014 01:49 AM
Rear trailing arm bushing failure sheki Defender Technical Discussions 23 July 5th, 2006 09:20 PM
remove front diff? scoloco Defender Technical Discussions 31 April 7th, 2005 03:23 AM
