Why is the engine set back so far on this truck? - Defender Source
Old November 21st, 2011, 09:10 AM
TravelerBT's Avatar
TravelerBT
Philip Marshall
none - :*(
http://cgi.ebay.com/ebaymotors/Land-...m=180753192614
I have seen this a lot on trucks coming over the pond and I am wondering why? The engine is smushed up against the bulkhead... they have to put extensions on the radiator hoses and stuff... just wandering why this seems to be pretty common...
thanks!
Old November 21st, 2011, 09:18 AM
Naplm00
Matthew
This truck was originally a gas engine truck, just like mine. My 200 tdi is in there the same way. It is also missing the fan shroud, that takes up alot of space and makes it look very roomy without it.
Don't buy from this guy
Old November 21st, 2011, 09:20 AM
TravelerBT's Avatar
TravelerBT
Philip Marshall
none - :*(
I figured it was something like that... and I am not buying at the moment... just curious thanks!!!
Old November 21st, 2011, 09:35 AM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
The frame looks like rust covered with chassis paint.
Old November 21st, 2011, 09:57 AM
Rugbier's Avatar
Rugbier
Gustavo
All 200 tdi seat really far back
NO SIGNATURE
Old November 21st, 2011, 10:01 AM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
A buddy of mine used to move his engine back as far as possible, stops it nose diving when all four wheels leave the ground when off road racing.
3rd low and BOOT IT
Old November 21st, 2011, 10:22 AM
Thie truck pictured has a 300 tdi mated to an Lt77. Normally the 300 would be mated to a long bellhousing r380 and would require different mounts be welded onto the frame farther foward. This is where all 200 tdi's were positioned and as said above they have long fan shrouds that eat up the space. There's nothing wrong about mating a 300 to an lt77. Its a simple matter of swaping rear seal holders and clutch covers. Not commenting on the truck-just the mechanical compatibility.
Old November 21st, 2011, 11:10 AM
T1G UP's Avatar
T1G UP
marcus
Puma 110 xs. Td5 110 xs for sale
You can buy a short bell housing for an R380 so a 300 set up will go in a 200 postion. It's the best set up for off roading as the weight back behind the front axle
2011. 110 XS SW. 1999 TD5 110 XS SW Project For sale
Old November 21st, 2011, 08:16 PM
draaronr's Avatar
draaronr
Here
LR3
Doug is absolutely correct and is as stated in the description.
Old November 22nd, 2011, 01:02 AM
headdamage's Avatar
headdamage
Andrew
exmod 90 2.5na and a 93/RRC 200tdi
That air filter or lack there of looks bad.
Old November 22nd, 2011, 01:09 AM
aka rover's Avatar
aka rover
ed angel
95 D90
The air filter looks like a ford type maybe but im sure breaths enough for that little motor. Looks ok to me.
Old November 22nd, 2011, 08:21 AM
Mine is set back like that too, with a 300tdi/lt77 combo. Someone also trimmed down the fan blades so it wouldn't hit the small coolant hose. I don't run a fan on it anymore, I may add an electric on in the summer.
ac, engine
FOR SALE - Set of Used Oil Cooler hoses / window studs eric_besore For Sale - Parts 10 August 31st, 2005 02:18 AM
Help with engine not starting cbass Defender Technical Discussions 4 April 5th, 2005 12:12 PM
