Why in blazes is my oil pan... - Defender Source
Old April 30th, 2013, 02:25 PM
UnfrozenCaveman's Avatar
UnfrozenCaveman
Keith Armstrong
Various
...glued on!? - '97 SW
Fought with the blasted thing on Sunday and thought I'd better quit before I break something.
I think I've decided that judicious use of a utility knife will let me break the bond and slip it off.
Any other ideas that won't lead me to the emergency room?
KAA
Old April 30th, 2013, 02:36 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
A ton of us use Right Stuff to seal the oil pan-- I bet that is what they used. I just start at one corner and pry up-- once it starts, it usually comes off fine.
Old April 30th, 2013, 03:01 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
When breaking seals on oil pans, I use an old flat griddle scraper and a hammer to get it started. Like previously mentioned, once you get it started, the pan will peal off pretty easy. A stout putty knife will work too.
Then comes the fun, cleaning off the old sealant.
Old April 30th, 2013, 04:41 PM
UnfrozenCaveman
Keith Armstrong
Various
Hate you "right stuff" guys
Hell, it wasn't leaking...maybe I should use that on the re-installation
KAA
Old April 30th, 2013, 04:48 PM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
KAA
It would almost certainly have been leaking if it was the stock gasket.... That's why we use the 'right stuff'....
Old April 30th, 2013, 04:57 PM
If it is not leaking, why are you taking it off.....
Old April 30th, 2013, 05:08 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
The factory gasket leaked and caused warranty issues, so the factory service bulletin recommended 'the right stuff'.
-Jeff
Really! I would think they'd just make a better gasket! Strange...
Old April 30th, 2013, 05:11 PM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
Why re-invent the wheel when the 'right stuff' stops it squeaking (or leaking in this case)?
Old April 30th, 2013, 05:49 PM
revtor's Avatar
revtor
Steve Maietta
1969 IIA 88" Bugeye
They tried for 60 years to make a gasket that actually seals and they couldn't so they turned to the goop...... It's good stuff
Old April 30th, 2013, 08:43 PM
UnfrozenCaveman
Keith Armstrong
Various
So I can get the timing cover off so I can replace the cam that was found to be bad aolng with the litters that look horrible after I pulled the heads to solve the coolant consumption.
No...no "shipfitter" issues here..none at all
Old May 4th, 2013, 02:32 PM
red64chevelle
Daniel Smith
86 110 300TDI,16 Disco Sport
I ended up using a dead blow hammer to get the pan off my 300TDI when I was rebuilding it. It did not bend/mar the pan at all. I went at it from the side and eventually it popped off.
75% of all Land Rovers ever made are still on the road...
the other 25% at least made it home.
Oil Pan Leak Eric Siepmann Defender Technical Discussions 11 May 25th, 2005 09:47 AM
Oil pan drain bolt size?? mspell Defender Technical Discussions 1 October 2nd, 2004 12:09 PM
