why does the air intake on the 3.9 constrict - Defender Source
Old December 12th, 2011, 06:57 PM
cdb
Clark Bowen
Starting from the air filter box intake (1995 RRC in this case); it expands through the intake trumpet, then expands about 1/2" when it exits the air filter box into the hose that connects to the MAF. On the other end of the MAF it shrinks a small amount and then when it hits the plenum intake (right before the throttle plate) it shrinks again by about 1/4".
It would seem to be very restrictive - especially the intake horn - at higher RPMs, but maybe I'm missing something.
Venturi effect?
Keeps water out of the filter housing?
Does anyone know why?
2011 RR HSE -
2001 GMC 2500 4wd
Old December 12th, 2011, 08:15 PM
To keep it quiet because women were complaining about intake noise. Run the canister style RRC intake without the trumpet its really loud. IIRC the piping on the RRC airbox is the same diameter after the maf.
Old December 13th, 2011, 12:32 AM
cdb
Clark Bowen
Philip.....
What does IIRC mean?
2011 RR HSE -
2001 GMC 2500 4wd
Old December 13th, 2011, 06:22 AM
gravitysucks's Avatar
gravitysucks
Andy
94 D90
Originally Posted by cdb View Post
Philip.....
If I Remember Correctly
air intake
In line blower for mantec raised air intake system LenB Smaller Projects 22 November 20th, 2009 08:24 PM
Late model intake manifold on 3.9? jaherring Defender Technical Discussions 11 October 31st, 2005 11:16 PM
Air Intake Cover wardnb Wanted 1 August 5th, 2005 08:53 PM
air intake hose?? / source for cheap switches NASD90 Defender Technical Discussions 15 July 6th, 2005 02:40 PM
Wing top Air Intake or Scoop??? adibitar Defender Technical Discussions 7 July 8th, 2004 08:57 AM
