Why does the AC fan come on sometimes during glow-plug cycle? - Defender Source
Old April 12th, 2011, 05:07 PM
Chaucer
Will
93 110 | 97 90
Anyone know why the AC fan would come on sometimes during glow-plug cycle on a 300tdi? Some mornings, when I go out to start the rig, and wait for the glow plug light to turn out, I have noticed that sometimes the AC fan comes on at the same time as the glow plugs. Does this have something to do with the contacts in the ignition?
Old April 14th, 2011, 02:23 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Nothing connects up from the A/c to the ignition switch on mine except for a switched power lead at the fuse panel. The glow plugs are on a separate power feed through a timer relay. However my A/C is an aftermarket made for the Defender and not a factory unit.
Land Rover 110
ac, fan
Help! need STC934 glow plug harness cabell Wanted 29 May 6th, 2015 08:05 AM
Pin-out for the PRC 6913 glow plug relay? dmarchand Defender Technical Discussions 7 July 10th, 2007 05:51 PM
Glow Plug Relay Michael Defender Technical Discussions 1 March 16th, 2006 02:28 PM
LR Glow Plug relay temp? dmarchand Defender Technical Discussions 0 June 9th, 2004 01:42 PM
