Why does my truck reak of gas? - Defender Source
Old November 29th, 2007, 09:22 PM
bjf's Avatar
bjf
barry f
94 ST #395
I just filled up and when I parked my truck in my garage I thought I was going to pass out. It smells like I dumped gas on the floor. It seems to smell like this in my garage everytime I get home lately. I am not dumping any gas that I know of so what gives?
Old November 29th, 2007, 11:09 PM
You probably have a split breather hose somewhere. Either the return hose to the filler or one of the small breathers coming off the top of the tank leading to the vapor recovery unit.
Old November 29th, 2007, 11:42 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
I'm assuming the Vapor Recovery Unit is the metal box in the RR wheel well with lines going to the tank? If so, is it the same on a 90 and a 110 and does anyone have a good one? Mine isn't leaking but it is so horribly rusted that I would prefer to replace it while I am doing all the rest of the work.
Old November 30th, 2007, 12:53 AM
bjf's Avatar
bjf
barry f
94 ST #395
Is it an easy fix?
Old November 30th, 2007, 07:19 AM
At least on the 94 and 95 defenders, the vapor recovery system goes through a plastic unit in the wheelwell and is routed all the way to the inside of the front right fender behind the headlight for the actual canister. Its super-easy to fix when you find the problem, but in Barry's case, the leak is probably on top of the gas tank, to which access is, to say the least, difficult. Both my 90's developed breaks on the vent hose running to the filler neck where the passed over the chassis rail. This resulted in a very clean trailer wiring harness, but an environmental disaster every time I filled the tank.
Here are a couple pics of the top of the tank. I didnt need vapor recovery for the diesel, so you can see where I blocked off the vapor recovery fittings. Note that there is also frequently fuel leakage from around the fittings themselves - the rubber gaskets dry out and leak fuel down the side of the tank and onto the skid plate, so you never see it, but you smell it. The blue hose (yours will be black) is the one that broke on both my the 90's - right where it passes under the wiring harness (note the harness on NAS trucks runs through the chassis rail).
ID:	11185   Click image for larger version
Old November 30th, 2007, 10:14 AM
bjf's Avatar
bjf
barry f
94 ST #395
Thanks for the info. Do I have to pull the tank to fix? Do I want to do this myself or bring it in?
Old November 30th, 2007, 01:54 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
I have not looked at the filler neck of the d90 before but if it was like my old range rover check the hose from the filler neck to the tank, make sure it isn't loose. My old rover reaked of gas after I filled it up also for this reason. Finally one day I was wheeling and got stuck while off camber got out only to witness gas pouring out from the filler neck. Probably not it but just a thought.
Old November 30th, 2007, 03:09 PM
bjf's Avatar
bjf
barry f
94 ST #395
thanks I will check that out
Old November 30th, 2007, 05:04 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Have you checked your diet? Maybe you need to cut down on the burrito intake?
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old November 30th, 2007, 07:14 PM
shawnpalmer's Avatar
shawnpalmer
Shawn Palmer
1997 SW-Arles Blue
I had a dry rotted filler hose and it was split and would spew gas after I filled up.
Old November 30th, 2007, 08:46 PM
bjf's Avatar
bjf
barry f
94 ST #395
any time i park the truck stinks. So is this a do it yourself job?
Old December 1st, 2007, 12:11 AM
Its DIY as long as you can get your skid plate to come loose (perhaps youre in luck if your truck has always been in LA). Best thing to do is buy all new hoses (filler, vent, breathers) and cut the ones you have to ease removal. The tank also needs to be pretty empty before you try to drop it unless you dont mind wresling a 75+ pound gas filled box out from under your truck.
Old December 1st, 2007, 12:49 AM
bjf's Avatar
bjf
barry f
94 ST #395
I was actually thinking of replacing the skidplate too. Here is a question, what happens if I do nothing?
Old December 1st, 2007, 12:57 AM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
This...
But seriously, there is no definitive answer as to what will happen but it is absolutely something that should be repaired ASAP. Not to mention, if you are parking it in your garage it is filling the garage with fumes which are highly explosive. It is a misconception that fuel is explosive. Fuel itself is highly flamable but it is the fumes that are explosive and far more dangerous.
Old December 1st, 2007, 12:59 AM
1000kva's Avatar
1000kva
paul girard
http://splodetv.com/tannerite-3-gallons-gas-fun
Tannerite+3 Gallons of Gas= FUN! | SplodeTV.com
Or I would assume something like that
gas
Mikes truck on the trail????? scoloco Trips, Trails and Events 20 October 27th, 2005 10:21 PM
Tethered gas cap??? Dredd Defender Technical Discussions 6 October 13th, 2005 04:22 PM
Summer Gas Mileage mdmccallum Defender Technical Discussions 5 June 9th, 2005 12:10 AM
Gas Cap leak Doug Defender Technical Discussions 7 April 22nd, 2005 01:03 PM
Gas Gauge Zimbo76 Defender Technical Discussions 7 May 13th, 2004 09:55 AM
