why do rovers rust so much? - Defender Source
Old December 3rd, 2012, 11:15 AM
wantone
Rick Thompson
94 ST #1222
why is it our beloved rovers rust so much? is it the alloy? or design of the frame? i was thinking about this last weekend while hunting and walking by a bunch of old (40's and 50's) cars on our friends farm. i mean these cars are 60+ years old and have rust of course, but nothing like a rover that is half the age or less. anyone know why? i figured it was the particular alloy of steel used.
Old December 3rd, 2012, 11:21 AM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
The older Land Rovers you can blame British Leyland using the cheapest steel in the world.
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old December 3rd, 2012, 11:24 AM
revtor's Avatar
revtor
Steve Maietta
1969 IIA 88" Bugeye
total lack of real preventative rust inhibitor on anything, and also when bare alum and steel meet, there is a chemical reaction that causes the aluminum to corrode away. Galvanic corrosion its called I believe??
Perhaps also the tendency for us to drive them through rivers and mudholes and then do a less than complete cleaning job afterward. The mud sticking in the crevices holds moisture and rust begins.
If the bodies weren't alum, there would be many less out there worth saving.. I think that has been rover's saving grace.
Old December 3rd, 2012, 11:35 AM
carlosz's Avatar
carlosz
Carlos
it is said that when the english find a formula they stick with it never looking back.. hence the same body style since 49 to present on the defender, and 70 to present on the rangie.
look at the jag sedan...
that being said, after ww1 there was a short supply of steel thruout europe and plenty of aluminum.. so to save the precius steel lots of carbon was used in it's manufacture, hence the high propensity of rust and the aluminum body shells of the majority of english cars.
well that formula worked then, why not use it now (their way of thinking).
Old December 3rd, 2012, 11:38 AM
The frame is boxed so stuff gets trapped inside. It is also much thinner than a comparable C channel frame. The bulkhead simply is not sealed off from water or treated inside in any way. Also keep in mind that the percentage of land rovers left is much higher than comparable cars and, Omaha is not exactly the center of the rust belt.
Old December 3rd, 2012, 12:28 PM
wantone
Rick Thompson
94 ST #1222
so the design and alloy is what it all pretty much boils down to then. are the new galvy chasis you can buy a different alloy? if it a modern type alloy, why do they galvanize them?
Old December 3rd, 2012, 12:32 PM
RoversNorth
RN
2012 Land Rover Defender
The chassis are steel.
Rovers North
1319 Vt Rt 128, Westford, VT 05494
Please message me with any questions you have.
Old December 3rd, 2012, 12:34 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
I would have to say that lack of quality or proper treatment from the factory. I have purchased many new items GEN land rover that are brand new in the bag that have rust on them due to quality issues or lack of proper treatment.
Even many of the bolts lack zinc or other coating to prevent rust
Old December 3rd, 2012, 12:47 PM
Have to agree with Dave on this. LR is one of the few brands where going with a genuine part isn't necessarily the best path to take when the quest is the longevity of your truck.
Old December 3rd, 2012, 12:48 PM
Maximal
Max
none
They used shit steel on them. Very similar to what happened witht he early tacomas/tundras that were recalled.
Old December 3rd, 2012, 12:58 PM
roverman2010
1985 LR 90 200Tdi
What he said
thats a fact jack
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old December 3rd, 2012, 01:00 PM
RoversNorth
RN
Originally Posted by roverman2010 View Post
thats a fact jack
Well clearly the problem there is the poly bushings caused the rot.
Rovers North
Old December 3rd, 2012, 01:05 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
Toyota gave me 150% of KBB for my Rusty Taco. That was about $3k more than I paid for it after owning it for 5 years
Toyota in Mexico was the one that screwed up. They did not properly wash the chassis prior to coating it. The coating never adhered. 550k trucks were part of that
consumer call back (not to be confused with recall).
Old December 3rd, 2012, 01:14 PM
Every great warrior, has an Achilles heel... :-)
Old December 3rd, 2012, 01:37 PM
jefferson's Avatar
jefferson
Jeff A
97 Defender 90 SW #593
I also had my Taco recalled and received the 150% of KBB deal, which landed me ahead of what I paid several years and several thousand miles earlier....has Rover ever addressed the common corrosion issues? I suspect not.
Old December 3rd, 2012, 01:38 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Get a Galvanized Chassis and be done with it. You can also Galvanize the new bulk head....
Land Rover 110
Old December 3rd, 2012, 01:43 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
We don't have it that bad. Just ask the owner of any Karmann built chassis through the mid 70s.
Old December 3rd, 2012, 01:45 PM
roverman2010
1985 LR 90 200Tdi
You mean like this
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old December 3rd, 2012, 02:27 PM
JohnsD90's Avatar
JohnsD90
74 SIII 88", 88 110, 91 110
HA! good one man, i got a 15 year old 4runner, way more rust than the 15 year old defender i had. I walk by new F250's and see the rust already on the door sills. Walk by any 5-8 year old American pickup truck and you will see rust on the body forming or holes already there unless the owner was very ontop of cleaning the salt off. American cars have always rotted out fast, ask muscle car owners from the era, cancer hits them too!
At work i see loads of Fords/chevy/dodges with holes in the frame and body and they arent as old as the rovers.
Old December 3rd, 2012, 02:28 PM
Any porsche prior to 1976 is rusty -- even ones from california.
D-90 Restoration / Rust Removal Flagg Defender Technical Discussions 20 March 14th, 2012 10:11 PM
fix for rust on rear crossmember/bumper d90_1372 Defender Technical Discussions 2 August 6th, 2004 08:38 AM
Playing with Rovers, guns and a hot blonde in Africa wicks Misc. Chit-Chat 1 February 21st, 2004 09:31 AM
