Why did my truck pop the bottom hose? - Defender Source
Old October 2nd, 2010, 07:08 PM
Ok so I've been using the car fine all day, just went to move it and got stuck in some traffic, the temp gauge kept rising and I could get it back down only when moving. Got home asap and parked up and found coolant coming out of the area near the bottom hose on the water pump.
I need to move the truck by end of tomorrow, so options:
Best case - it's popped the bottom hose because the fan failed to cut in? Reseat / repair hose - limp to somewhere I can work on the truck properly?
Should I throw in some Radiator stop leak?
I checked the fan operation only yesterday ... but Is suspect it's a bit temperamental ... is that possible??
Is it possible to force the fan to run all the time?
Worst case ... Fan clutch? Water Pump?
------ Follow up post added October 2nd, 2010 08:03 PM ------
OK so a bit of torch light spannering, removed the hose and reseated it ... the jubilee clip didn't look like it was in a great place ... so hopefully have put it in a better location.
I did notice in the workshop manual that the thermostat needs to be orientated with the little hole at the top ... I didn't know this so will need to investigate that ... can cause an air lock and associated fluid loss ....
Nightmare scenario head gasket?
Old October 3rd, 2010, 09:20 AM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
Ok, why don't you start by telling us what changed since you have this problem. You installed a new Thermostat? Did you bleed the cooling system?
What type of coolant are you using?
When is the last time you fluted your cooling system?
Typically, the problem you describe is due to a failed or failing fan clutch (that is "if nothing changed since it worked"). But of course, there could be other issues.
MonLand
1995 D90 NAS
1996 Discovery NAS
Old October 3rd, 2010, 11:40 AM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
x2
Probably simple.
Evaluate the fan clutch (search here) tighten the hose. Re fill the system and bleed.
Dont let it get hot though. If that does not do the trick... look at your radiator, then start thinking about bigger things.
Old October 3rd, 2010, 12:13 PM
Head gaskets aren't that big a deal. Time consuming but not difficult.
Old October 3rd, 2010, 09:06 PM
The water pump decided to retire .... What a pig of a job! I couldn't get the fan off, was worried I'd break something to took out the rad to get the clearance for some long bolts ...
I'm just about to order up some spares ... Is the consensus to change the fan clutch at the same time?
Old October 4th, 2010, 05:44 AM
MonLand
Loic Fabro
I would re-bleed the cooling system and make sure there is enough coolant. Did you crank up the cabin heater up to force the air out? Of course you have to make sure the thermostat in correctly installed too since it seems it was not. Personally, I would not throw parts at the problem. You can check that the fan clutch is working (do a search here) [actually... Why don't you change it, I'll buy your broken one for $30 including shipping! ]
MonLand
1995 D90 NAS
1996 Discovery NAS
Old October 4th, 2010, 08:47 AM
Every time I've tested it it seems to lock up ... I can't count the number of battered rolled up newspapers I have ... any more parts I should change? ;-)
Air intake hose, fuel filler hose and neck SafariHP The Vendors Loft 0 May 18th, 2008 08:52 PM
Hose replacements kolvedic Defender Technical Discussions 1 March 14th, 2006 04:50 PM
What size is the lower radiator hose? Hans Defender Technical Discussions 2 February 11th, 2006 06:29 PM
And I thought the D-90 looked like a dump truck! OCD90 Misc. Chit-Chat 0 September 16th, 2004 07:40 PM
removing weather stripping from door bottom JRowe Defender Technical Discussions 4 November 6th, 2003 01:53 PM
