Why can't I bleed this clutch??? - Defender Source
Old October 25th, 2015, 06:41 PM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
Okay,
Its not like I've never bleed brakes or a clutch before (Okay, is been quite a few years). Master cylinder is full, clear tubing hooked to bleed nibble on clutch slave. Bleed screw open a few turns (almost ready to fall out). No fluid when I pump the pedal...
I didn't replace the slave, just the master. Is it possible there is debris somewhere in the circuit clogging it up? Am I missing something? There is now resistance in the pedal, and the initial fluid level in the master dropped, but not dropping anymore (Actually feels like you are disengaging the clutch)..
I give up If anyone has any ideas, they are much appreciated, thanks..
~Scott T.
'95 D-90 ST - AA Yellow
Old October 25th, 2015, 06:49 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
Did you bench bleed it first before installing? I find reverse bleeding the line works the best on these. You have an air pocket in the master...
Old October 25th, 2015, 06:53 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
You need to bench bleed the clutch master before installation.
Try having the petal all the way down and place your palm over the reservoir then lift the petal so it sucks in fluid. Repeat until pressure builds. Then with the petal down open the slave bleeder... yadda yadda
RDavisinVA
Old October 25th, 2015, 06:54 PM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
No, not sure how to bench bleed to be honest, put it back together, and not get fluid everywhere..
Please tell me I don't have to take the ****** Master back out...
~Scott T.
Old October 25th, 2015, 06:56 PM
^this. Anytime I've used the regular Rover master I've had to do the same as well. However, I recently switched to the cast-iron Dorman conversion (thanks to Briggs talking me into it), and didn't have to bench bleed it - gravity bleeding was fine (didn't even have to use a pressure bleeder actually). I need to get off my butt and do a write-up for the Dorman conversion, it's been a great upgrade/conversion.
------ Follow up post added October 25th, 2015 06:59 PM ------
Reverse bleeding it probably best...but a huge pain in the arse. That said, I've always done a traditional bleed via pressure bleeder or the old fashioned pump the pedal method.
Old October 25th, 2015, 07:12 PM
RiftRover's Avatar
RiftRover
Mike Barnett
110
I did mine recently and didn't bench bleed the master. Maybe i just got lucky...
Old October 25th, 2015, 07:28 PM
The problem is normally the slave end as the routing traps a bubble. If you pull the slave and hang it down, it will bleed right away. In place you need to purge it out just the right way.
Old October 25th, 2015, 07:56 PM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
The pedal actually feels solid, like its disengaging the clutch. When I started, it was soft, (had to pull it back up manually). Would I be able to get pedal feel like that if it is an air bubble?
Tried backing the bleeder out even further, still nothing coming out
Frustration is setting in..
~Scott T.
Old October 25th, 2015, 08:47 PM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
Got a Dribble of fluid, then nothing. Backed the bleeder out entirely, and blew compressed air through it, not the issue (not that I thought it was). I guess the next time I have time to play with the truck I will try to pull the slave (Guess I will just replace it at this point as well) and see what happens..
Looks like it is going to be a pain to get out around the exhaust
~Scott T.
Old October 25th, 2015, 11:10 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
Try jacking up the front end as much as you can...
Old October 25th, 2015, 11:19 PM
Disconnected the return spring, push the pedal with your right hand while opening the nipple with the left hand. Worked for me.
Old October 26th, 2015, 01:17 AM
Departing90
Sasha
95 D90
Undo the one hose that goes into the mc
Have a helper press the clutch pedal ro tye floor while you pour fluid into the opening
When the pedal is lifted it will suck the fluid in & prime the mc
Repeat a couple of times and reattach the hose. Now the mc is primed
Crack the beeder nipple on the slave cylinder 1/4 of a turn and attach a clear hose on it. Put the other end of the hose in the mc and secure it with a zip tie. Fill the mc with fluid.
Pump the clutch pedal about 15-20 x untill all bubbles are purged
Close the bleeder nipple on the slave and remove hose
No fluid waste, no mess and your done.........
Old October 26th, 2015, 08:04 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Had an issue like this in an MG years ago and here's what solved it.
I washed out a 90wt oil container with nipple top with alcohol.
Then cut the top off to create an opening at the very end of the nipple.
Then attached a vacuum line at the end of the nipple.
Next poked a hole in the bottom of the container.
Then filled the container with brake fluid.
Next, put some wire around the container to hang it higher than the master cylinder.
Next connected the vacuum line to the bleader on the slave cylinder.
Next hung the container upside down higher than the master cylinder.
Next cracked the metal line coming out of the master cylinder.
The fluid ran from the bottle, through the vacuum line into the slave cylinder up the line forcing out all the air.
Be sure and wash the brake fluid away so it doesn't damage the paint work.
RDavisinVA
Old October 26th, 2015, 09:15 AM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
I'll give it a shot!
Your arms must be much longer (and stronger) than mine..
I actually tried this last night (Cracked the Fitting at the MC and Cycled the clutch, getting fluid out around the fitting. Guess I will try it a few more times see if that helps..
Crack the bleeder nipple on the slave cylinder 1/4 of a turn and attach a clear hose on it. Put the other end of the hose in the mc and secure it with a zip tie. Fill the mc with fluid. Pump the clutch pedal about 15-20 x until l all bubbles are purged
I have a bleeder bottle attached to the bleed nipple. I don't want to recycle the fluid at this point, as I want to flush the circuit first..
Head Spinning, think I follow you, essentially creating a MityVac?? but I don't have access to a vacuum source..
What really baffles me at this point is how the clutch pedal can be so firm, that it feels like I am actuating the clutch, but nothing comes out of the bleeder. I would think trapped air would leave the pedal with little or no resistance?!?!
Anyway, Thanks Everyone for your input. May not be till next weekend that I get the time to get back to this and try all the suggestions. But much appreciated!
~Scott T.
Old October 26th, 2015, 09:58 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
The scenario I described uses gravity with hydraulics, no vacuum source required.
RDavisinVA
bleed, clutch
Clutch does not engage - do I need to bleed? sro Defender Technical Discussions 18 January 2nd, 2013 11:28 PM
Clutch Slave cylinder bleed?? Quimbola Defender Technical Discussions 2 February 10th, 2009 11:17 PM
Why oh why (aka broken CV joint) bharris Defender Technical Discussions 39 January 22nd, 2008 12:08 AM
WHY WHY WHY am I blowing through suspension bushings? KevinNY Defender Technical Discussions 27 September 13th, 2007 02:29 PM
Calipers and Bleed valve jabber Defender Technical Discussions 4 December 22nd, 2004 11:54 AM
