Why are top bushings being shredded on shock tower - Defender Source
Old July 9th, 2014, 04:41 AM
landrovernewbee
mark defrates
1996 defender 110
New to the land rover scene. I have a 1996 defender 110. Trying to figure out why the top bushings on shock tower are being shredded after 3-4 weeks of being replaced?
Old July 9th, 2014, 06:04 AM
Could be the dished washers are on the wrong way
Old July 9th, 2014, 07:00 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Could be bad bushings.
I installed some Old Man Emu shocks a few years ago(new, old stock) and within 2 weeks the bushings literally fell apart.
Rent my
Old July 9th, 2014, 07:53 AM
What brand bushings?
Old July 9th, 2014, 09:15 AM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
This. Go Poly or actual Genuine.
Old July 9th, 2014, 09:18 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Guessing dish is inverted and it's over torqued, or bad bushings. Also, any fluid leaking on them?
Old July 10th, 2014, 10:20 AM
landrovernewbee
mark defrates
1996 defender 110
Thanks for reply, they were on correctly.
------ Follow up post added July 10th, 2014 05:29 PM ------
They are OEM, name is britbuilt I believe. One thing we found is that the hole in the top of tower has been egged out a little, so we re-did them and seems to be ok now, but time will tell. How can you tell if over torqued??? Thanks for the responses, i'm new to the landrover world, but learning very quickly. These vehicles are a little different than what i'm used to.
Old July 10th, 2014, 10:44 AM
BritPart is generally regarded as inferior aftermarket, not OEM by any means (China). You should think about Bilsteins or similar quality shocks at some point. In the meantime, I'd pop for polyurethane bushings. You tighten them until the top washer bottoms out on the shoulder of the top pin threads.
Old July 10th, 2014, 10:48 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Hopefully not britpart.... that could be your issue.
Old July 15th, 2014, 10:44 AM
landrovernewbee
mark defrates
1996 defender 110
Thanks for the info on brands. Wow, britparts are more than inferior. Am now finding place to get original. Thanks again
Old July 15th, 2014, 11:00 AM
dolomiti
1987 One Ten
Bilsteins are significantly better than OME?
Old July 15th, 2014, 12:15 PM
Bilsteins are significantly better than BritPart
Old July 15th, 2014, 12:28 PM
dolomiti
1987 One Ten
Ah, yes. He said he has Old Man Emu shocks and you mentioned Bilsteins as an upgrade, so I was just asking for clarification (before I order OME).
Old July 15th, 2014, 12:56 PM
I read it that he had "OEM" ones...Britpart.
Old July 15th, 2014, 01:02 PM
dolomiti
1987 One Ten
This is what I meant.
bushings, top
external shock tower (w/o cutting arch) sflash868 Defender Technical Discussions 3 July 2nd, 2008 01:00 PM
Loop mount front shock tower? cellulararrest Defender Technical Discussions 19 March 17th, 2008 09:20 AM
WHY WHY WHY am I blowing through suspension bushings? KevinNY Defender Technical Discussions 27 September 13th, 2007 02:29 PM
Rubberized Spring Isolators/ Shock Tower Securing Ring? oldscratchggf Defender Technical Discussions 10 October 2nd, 2006 05:44 PM
Fitted Rubber Shock Tower Retainers wicks Misc. Chit-Chat 21 March 28th, 2004 10:51 AM
