Why are there so many Stepper motors? - Defender Source
Old September 29th, 2014, 01:46 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
So last issue i'm trying to solve on my truck is the stepper motor. Engine was dying at stop lights so i ordered a new one from AB. Didn't think anything of it, threw it in the truck and now on start up it revs to 2500 RPM and stays there for 30-45 seconds. Then is it will drop to 1500. It cost me like 150 bucks or something. Figured it was a defective part. Ordered another one from Lucky 8 which cost 70 bucks and had a different part number. I compared both side by side the one from lucky 8 has shorter threads and a longer plunger. otherwise look identical. Installed the lucky 8 one and now on start up it revs to 1500 rpms and then drops to 1100 and causes slight surging when driving in the lower RPM range. These all come in a made in china box and have have gold colored plating around the part. Took the part from my brothers 94 D90, which is all black in appearance, put it in after trying these two and the truck runs perfect. Idle sits at 800, doesn't randomly rev and no surging. I went to Rovers North's site and now I see a Stepper motor for 528 bucks???! Part # RNM077. I also see another stepper motor for 169 bucks. Part #PLM077. Both are for the Defender and are different part #s from what AB and lucky 8 sent.
What's the deal? Doesn't anybody know the actual correct part # for a genuine replacement?
Old September 29th, 2014, 01:50 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
get one from a junkyard Astro van. Its the same part.
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old September 29th, 2014, 01:51 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
What's your vin?
Old September 29th, 2014, 01:54 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
Saldv3280sa980651
Old September 29th, 2014, 02:00 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
ERR2263, looks NLA and aftermarket may not be available either...
Old September 29th, 2014, 02:11 PM
ini88's Avatar
ini88
Daniel Marcello
3.9 idle air control valve IAC valve stepper motor - NAPA Part # MPF21738
3.9 idle air control valve IAC valve stepper motor - AC Delco Part Number #25527077
4.0 idle Air Control Valve stepper motor - AC-151
1955 Series I
1975 FC101 Vampire
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old September 29th, 2014, 02:13 PM
Stepped motors need to adapt. It really needs to run for a good 15-30min before they settle in. Disconnect the computer to reset it. Fit the stepper motor, and then let it idle for a while. Not saying the ones you have are good, but doing this should help. Also, one off a disco 1 94-95 or 91 and up RRC should work. Usually if you clean them and the socket and have no vacuum leaks they are fine in my experience.
Old September 29th, 2014, 02:35 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
The main reason I figured it was the wrong part or defective, was because the threads didn't seems to line up right. the IAC from the other defender has no washer, and threaded in tight and snug. These other ones had some cardboard washer with them (i tried with and without washer) and they don't thread in tight. Forget putting a wrench to it, I hand tightened it and stripped the threads closest to the base on both the lucky 8 part and AB part. As it sits now, you can un crew my stepper motor by hand since I can't take a wrench to it. The threaded body on the black stepper motor is an 1/8 inch shorter than the other two.
I have a Napa right near me, I'll try that part # and see what comes out.
Old September 29th, 2014, 02:40 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
Any idea why Atlantic British lists different part numbers for the stepper between D90/RRC and 94/95 D1's ?
Old September 29th, 2014, 02:42 PM
Dogpilot's Avatar
Dogpilot
James Wallace
Defender 90 1997 NAS ST
Couple of other things. Check the wires on the connector, they go as bad as the steppers do. It was actually a poor connection on My old Disco 1 that was my problem. That and you need to use some carb cleaner to clean the orifice and mating surface of the plunger and in the plenum itself. The deposits are sticky and also affect its performance. On some aftermarket steppers the plug was mated 90 different.
Old September 29th, 2014, 03:06 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
As Ron said, remove power from the ECU then try again. It could take a few short trips. FWIW, I've tried two steppers before settling on a NOS Lucas stepper purchased here that was clearly used. It works perfectly.
Old September 29th, 2014, 04:19 PM
robertf
Robert F
1995 Discovery
The stepper resets when the car is shut off. That buzzing sound is the stepper slamming in to the seat. There is no learning process for the idle
Old September 29th, 2014, 04:22 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
I never reset the ECU, but I have driven well over 45 mins on each one with no change.
I looked at the wires and yeah, each times the plug is in a totally different position. I've ruled out any other issues because I have one original stepper motor from another truck that when plugged in runs perfectly fine. That without re setting the ECU. What blows my mind.. is the physical dimensions of each plug is different yet each one is for a 94-95 defender 90 and cost btw. 70 and 528 bucks. Don't understand how that works.
Old October 9th, 2014, 08:58 PM
Sned's Avatar
Sned
1994 NAS D90
I tried a cross-over referenced one from NAPA $70. No go. My mechanic put in an OEM Lucas and it runs like a champ. Go figure.
Old October 9th, 2014, 09:21 PM
Grover's Avatar
Grover
Yes...I bought a stepper motor (I think the brand is BWT?) from Pep Boys. I didn't want to blow their minds telling them it was for a D90, is stated it was for an 1986 Astro van. No problems in the last 3 years and it was $15...
Good luck...
Old October 9th, 2014, 09:30 PM
genie90's Avatar
genie90
Jay Geaney
1994 D-90 ST #282
Good luck...
Concur-
"I'd like part# AC-102."
"Okay what's it for?"
"I'd just like part# AC-102."
"Just need to see if it fits."
"Okay it's for an '86 Chevy astro."
"Okay great it fits! Here you go."
Mentally: "GFY..."
Old October 10th, 2014, 06:09 AM
Grover's Avatar
Grover
Originally Posted by genie90 View Post
Concur-
Mentally: "GFY..."
You nailed it!
$528 for a stepper motor is insane! My guess the part is $28 and the Land Rover box is $500...
motor
1998 = No More NAS Defenders. How Many Rumors Are There? rijosho Misc. Chit-Chat 24 July 23rd, 2013 02:14 AM
Just how many different water pumps are there for 200tdi? o2batsea Defender Technical Discussions 2 August 27th, 2012 07:00 AM
Just how many different swivel housings are there? o2batsea Defender Technical Discussions 1 June 24th, 2012 09:25 PM
WHY WHY WHY am I blowing through suspension bushings? KevinNY Defender Technical Discussions 27 September 13th, 2007 02:29 PM
why Rover motors are crap junkyddog11 Defender Technical Discussions 2 May 12th, 2007 07:28 AM
