Who's selling galvy chassis? - Defender Source
Old January 12th, 2016, 12:16 AM
TheOneTen's Avatar
TheOneTen
Eric Wages
1988 D110 300tdi/R380
Which vendors are currently importing and selling galvy chassis in the US? And what brands are they selling?
I've done a bunch of research, but it's certainly not exhaustive. It's clear that Rovers North is selling chassis, but not sure of the manufacturer. Maybe someone can clarify.
Anyone else have updated (and/or verified) info?
Old January 12th, 2016, 01:01 AM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
Safari HP sells Marsland which is the best imho
Old January 12th, 2016, 01:05 AM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
Defenders Northwest. They sell Richards Chassis. I bought one from them and it's awesome.
1987 Ex-MOD 110 Tithonus LHD
2013 LR4
Old January 12th, 2016, 08:15 PM
TheOneTen's Avatar
TheOneTen
Eric Wages
Any others?
Old January 12th, 2016, 08:42 PM
UserName's Avatar
UserName
Andy
Janey
Atlantic British sells them for 90's. Not sure who's they sell.
ULC has them too but seems like you might want to ask around before buying from them.
This Ad Space For Sale!
Its the only space left on this site not already running a slow loading pop-up commercial.
Comes with free cookie downloader and user tracking virus. (superior to the ones Vertical Scope downloaded onto your computer when you logged in)
Old January 12th, 2016, 08:56 PM
UserName's Avatar
UserName
Andy
Janey
Just remembered another one: D.A.P. in Springfield, VT sells galvi ones too.
Old January 12th, 2016, 09:19 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
We(Rovers North) sell Marsland for all our defender chassis, there's no comparison between that and the Richards if you're comparing them bare. We sell Richards for series because Marsland doesn't do series anymore.
Old January 12th, 2016, 09:40 PM
TheOneTen's Avatar
TheOneTen
Eric Wages
Is Marsland able to do hybrid chassis (eg, a 300tdi 110 w/ a steel fuel tank option)?
Old January 14th, 2016, 10:35 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Yes they are.
Old January 14th, 2016, 10:56 AM
chuckc4
chuck b
Registered User
Hi Zach, can you expand on that a bit--what makes a Marsland better than a Richards?
Old January 14th, 2016, 11:01 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Construction and build quality. If you put the two next to each other it's obvious, harder to explain on the internet
Old January 14th, 2016, 11:30 AM
JohnsD90's Avatar
JohnsD90
74 SIII 88", 88 110, 91 110
From Marsland website:
"Main legs are in pressed pieces as original made from 2mm steel with 3mm stiffeners fitted and spotwelded internally for added strength where outriggers and suspension mounting points are fitted, effectively giving you 5mm of material where most needed."
From Richards website:
"Our chassis are made using 2.5mm side rails which are 25% heavier than the standard 2.00mm rails. Overall this gives a small increase in the vehicle weight but has a massive effect on the long term durability of the chassis."
It sounds like the reason that Richards is not made like they were in the factory is because they use 2.5mm steel vs 2mm at marsland.
Zack, did you sell both of them in the early 90's, or just one? My series has a RN galvy chassis put in in 92 and its in good shape.
Old January 14th, 2016, 12:00 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Originally Posted by JohnsD90 View Post
From Marsland website: "Main legs are in pressed pieces as original made from 2mm steel with 3mm stiffeners fitted and spotwelded internally for added strength where outriggers and suspension mounting points are fitted, effectively giving you 5mm of material where most needed." From Richards website: "Our chassis are made using 2.5mm side rails which are 25% heavier than the standard 2.00mm rails. Overall this gives a small increase in the vehicle weight but has a massive effect on the long term durability of the chassis." It sounds like the reason that Richards is not made like they were in the factory is because they use 2.5mm steel vs 2mm at marsland. Zack, did you sell both of them in the early 90's, or just one? My series has a RN galvy chassis put in in 92 and its in good shape.
Sweet -So the Marsland chassis are internally butted?
While apples to oranges - higher end bike frames use butted tubing as the weight to strength ratio is much better as well as the flex / force distribution.
Both should be better than stock LR save for a Perentie.
I have a RN/Marsland and have been happy with it. Things lined and matched up well and that galvy finish :D
Old January 14th, 2016, 01:05 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
I wouldn't say butted. That implies it is a single piece formed to different thicknesses. Id say laminated, sandwiched, internal gusset, or has a backing plate, etc. -Jeff
Should have added a smiley on my post. Internal gusset would be a better description but butted just sounds cooler, haha
FML just missed a great deal on a tdi galvy chassis 83 110 evilfij Misc. Chit-Chat 4 July 8th, 2009 04:35 PM
1984 Land Rover 90 TDI w/ Galvy Chassis Buyrovers For Sale - Vehicles 11 April 14th, 2009 01:34 PM
Euro Spec D90 200TDI Galvy Chassis brn24whl The Vendors Loft 4 August 15th, 2008 10:01 AM
1967 Series IIa 95% rebuilt with Galvy chassis Dfndr90 For Sale - Vehicles 1 July 12th, 2007 01:27 PM
Thoughts on galvy chassis? dmarchand Misc. Chit-Chat 2 October 17th, 2003 02:09 PM
